• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    hunt4one
    Point Group Properties
    197 Views, 3 Replies
    01-03-2013 10:09 AM
    I know that there used to be a way in land desktop to change an entire point group to the same layer without having to do each point separately. Can somebody please tell me how to do this in Civil 3d 2011?
    Please use plain text.
    Re: Point Group Properties
    01-03-2013 10:20 AM in reply to: hunt4one
    Right-click on point group, Edit points
    Is there a layer column in the panorama?
    If so
    Select all the points in the panorama  (Ctrl+A)
    Click on the word "Layer" (the column heading)
    select 'Edit'
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    01-03-2013 10:30 AM in reply to: hunt4one
    Option 2: Right-click the group in Prospector, choose Select, change the Layer on the Properties palette.
    Active Member
    hunt4one
    01-03-2013 11:15 AM in reply to: Jeff_M
    Thanks Jeff, that worked great.
