• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    sohaibamil
    Accepted Solution
    Point File on to the Surface
    299 Views, 5 Replies
    01-26-2012 08:33 AM
    Hi, I am a final year grad student doing my Final year project on Implementing BIM on Infrastructure. I am Facing A Issue Which Occurs When Ever i tried to insert Point file to my surface .... I have extracted the point data from drawing and its file is attached . the Point file dailog box give error "NO point file format match found" . Am stuck here and dont have any idea what to do .
    Please use plain text.
    *Expert Elite*
    Joe-Bouza
    Re: Point File on to the Surface
    01-26-2012 08:52 AM in reply to: sohaibamil
    Excel is not a OOTB defined point file format. you need to export to an ASCII file of the appropriate format. If I understan correctly.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Distinguished Contributor
    dibr0804
    01-26-2012 11:58 AM in reply to: sohaibamil
    Pick the ENZ (comma delimited) when you go to load in points.
    And load in this file..
    I set it up as a E N Z, .csv file
    Member
    sohaibamil
    01-26-2012 12:10 PM in reply to: sohaibamil
    Thanx Alot Sir..
    May i just asked what u did ..... Now i want to level the surface and Change the Soil since its situated near Beach and the whole Soil need to change how should i do that
    Thanx for the help sir one more time Cheers
    01-26-2012 12:34 PM in reply to: Joe-Bouza
    Yep Save As CSV and you should be G2G.
    Eric Collins, P.Tech.(Eng.)
    Win 7 Pro SP1 64 bit
    Intel i7 3770 @ 3.40 GHz
    16 GB RAM
    Civil 3D 2014 (IDSP)
    01-26-2012 12:35 PM in reply to: ericcollins6932
    oh, and you must have run this through geographic calculator as all your numbers are text - convert your text to numbers first.
    16 GB RAM
