• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    rkmin
    Accepted Solution
    Point Description gets truncated
    94 Views, 6 Replies
    11-28-2012 09:11 AM
    In LDDT 2009, I was able to describe points like this: STK #32
    But in Civil 3D 2013, whenever I use the # symbol, the description gets truncated.  So, using the point description above, it will show up in Civil 3D 2013 as STK rather than STK #32.
    Is this a setting or something that I can switch on so that the I can use symbols such as # and - in my point description?
    Please use plain text.
    *Expert Elite*
    Re: Point Description gets truncated
    11-28-2012 09:41 AM in reply to: rkmin
    Are you using Description Keys? If so, check the Format column of the description key that is not working. Try setting that to $* and see if you get the # sign.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Valued Contributor
    rkmin
    11-28-2012 09:54 AM in reply to: tcorey
    Yes, I checked the description key format and it is set to $*.
    Valued Contributor
    rkmin
    11-28-2012 10:04 AM in reply to: rkmin
    Is it something to do with the Point Label Style for "description" that I have to change?
    *Expert Elite*
    11-28-2012 10:08 AM in reply to: rkmin
    It's possible that you have Raw description being called rather than Full Description. Check the Contents of the Description component of your label style.
    Tim Corey, Owner
    Redding, CA
    Valued Contributor
    rkmin
    11-28-2012 10:14 AM in reply to: tcorey
    It was already set to Full Description.
    Valued Contributor
    rkmin
    11-28-2012 10:18 AM in reply to: rkmin
    I got it to work.  I changed it to Raw Description, reimported the points and it showed up they way I wanted to.
    Thanks for your help.
