AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Please need help Depth analysis between two surface
- Highlight
- Email to a Friend
I have two surface ( OG surface and Gravel LIFT ), i need to have a table that Show me Depths range between those two surface with a color range, in a table and also to be able to see it in the the top surface.
Basically, In every Spot of the surface, need to represent a Depth range between the OG and the gravel surface by a specific Color.
Thanks Guys.
i really need your help Guys.
Re: Please need help Depth analysis between two surface
- Highlight
- Email to a Friend
What you need to do is create a TIN Volume Surface. That surface will be the comparison between the other two. Simply apply Elevation syle settings and range values as you would for a normal surface, but these values will represent the differences in your two surfaces not actual elevations.
Tim
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
- Highlight
- Email to a Friend
...And you can add surface labels on a grid over the surface if thats the kind of thing you like.
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
- Highlight
- Email to a Friend
