• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    james.gabriel
    Accepted Solution
    Please help create a surface from this survey.
    198 Views, 4 Replies
    02-06-2013 12:55 PM
    I used to be pretty good at this back in the LDD days, but not now...
    I just cant crate a surface from this survey...
    Any help greatly appreciated...
    Thank you in advance.
    jim
    Please use plain text.
    *Expert Elite*
    Re: Please help create a surface from this survey.
    02-06-2013 01:17 PM in reply to: james.gabriel
    Have you worked through the Civil 3D tutorials?  They cover the basics qutie well.
    Creating a surface is easy:
    1. Create surface
    2. Add data to surface
    The hard part is that it depends on what data you have.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Valued Mentor
    Valued Mentor
    sjg
    02-06-2013 01:19 PM in reply to: james.gabriel
    Did someone do a topo survey for this area? If so, hopefully you won't plan on using it for any design. They really did a number on the contours with smoothing.
    Steve Goessling
    Land Consultants
    Civil3D 2012 (Service Pack 2.1)
    Windows 7, 64 bit
    Intel i7 2600 @ 3.40Ghz
    16 GB RAM
    Nvidia Quadro 600
    *Expert Elite*
    TRogers
    02-06-2013 01:27 PM in reply to: james.gabriel
    Just like troma said...
    Create the surface.  Then add the data.  In your case the data to add are contours because you have polylines with elevation on them.  I did the surface for you, but it's too large to attach here.
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    Active Contributor
    02-06-2013 02:01 PM in reply to: james.gabriel
    After you add the contours you can augment the surface by adding the spot elevation blocks.  They all appear to be on the correct elevations.
    Select one of the blocks, the right-click and press select similar.  Then type the select command.  It should add the 432 SPTELV Blocks to the current selection set.
    Then go to the Drawing Objects collection for your surface and select  Add...
    Change object type drop down to blocks.  When it asks you to select objects, type in P (for previous).  It should say 432 found.
    Using contours is my least favorite way to create a surface.  Someone else (probably surveyor) created a surface and sent you contours and spots.  Getting the original surface as a LandXML file would be best, or if they can send you the 3dFaces it would be good.  It also appears your drawing has some contour objects on elevation 0.
    Adding a boundary from the line on layer MAP-DATA is also a great idea, it will keep the TIN from widening ouside the orignal data where you transition from the site to the roadway.
