AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Please help create a surface from this survey.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I used to be pretty good at this back in the LDD days, but not now...
I just cant crate a surface from this survey...
Any help greatly appreciated...
Thank you in advance.
jim
Re: Please help create a surface from this survey.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have you worked through the Civil 3D tutorials? They cover the basics qutie well.
Creating a surface is easy:
- Create surface
- Add data to surface
The hard part is that it depends on what data you have.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Land Consultants
Civil3D 2012 (Service Pack 2.1)
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Just like troma said...
Create the surface. Then add the data. In your case the data to add are contours because you have polylines with elevation on them. I did the surface for you, but it's too large to attach here.
*Civil 3DJ*
Todd Rogers
Visit my blog here.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
After you add the contours you can augment the surface by adding the spot elevation blocks. They all appear to be on the correct elevations.
Select one of the blocks, the right-click and press select similar. Then type the select command. It should add the 432 SPTELV Blocks to the current selection set.
Then go to the Drawing Objects collection for your surface and select Add...
Change object type drop down to blocks. When it asks you to select objects, type in P (for previous). It should say 432 found.
Using contours is my least favorite way to create a surface. Someone else (probably surveyor) created a surface and sent you contours and spots. Getting the original surface as a LandXML file would be best, or if they can send you the 3dFaces it would be good. It also appears your drawing has some contour objects on elevation 0.
Adding a boundary from the line on layer MAP-DATA is also a great idea, it will keep the TIN from widening ouside the orignal data where you transition from the site to the roadway.
