• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Pipes - Using Civil Design 2005
    55 Views, 1 Replies
    08-12-2004 02:00 PM
    I have created 2 separate pipe runs; new run and proposed run. I want to connect the end of the propsed run to a point in the existing run. How do I connect it and how do I hold the invert at the connect to the existing?
    Please use plain text.
    *Conan Witzel
    Re: Pipes - Using Civil Design 2005
    08-13-2004 05:54 AM in reply to: laffa2
    You may want to post in the land Desktop forum but: You will need to have a node on the existing run. Then snap the end of the proposed run to the node. You can adjust the invert in the editors, either graphical or db. Hope this helps, conan witzel
