• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    New Member
    Pipes Interference Check Performance (Civil 3D 2012)
    200 Views, 0 Replies
    09-06-2012 09:21 AM
    Dear All,
    I have run pipe interference check between two medium sized networks and it takes alot of time (25 minutes to finish). The pain in this is that you have to re-run the interference check each time you modify any of the networks elevations.
    Is there a way to have this process done more efficient? I am not interested in interference between pipes and structures, I need only to get interference between pipes of the two networks. Is there a way to exclude the structures of the two networks from the interfernce check?
    The same problem is in Civil 3D 2013.
    Thanks in advance
    Mohamed Elkordy
    Please use plain text.
