AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Pipe tee
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is there a way to place a node within a pipe length without splitting the pipe in two? Our application for this would be catch basin leads wherein connecting to the mainline would not always require a manhole.
Any comments would be greatly appreciated.
Re: Pipe tee
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't think this is currently possible. We have needed this functionality ourselves and are not aware of any ways to do this without creating multiple pipe segments. If anyone knows othwerwise please share.
Civil 3D 2012
Windows 7 Pro (64bit)
Intel Xeon W5580 @3.20GHz
12gig RAM
NVIDIA Quadro 600
Re: Pipe tee
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Civil 3D will want to split the pipe to put a 'null' structure to connect another pipe. However, on a labelling basis, you can use a 'Spanning Pipe' label to make the split pipe appear as a whole pipe.
Or, you can add the crossing pipe in on a different pipe network, making it appear to connect to the original pipe, but C3D doesn't actually make the connection. I did this with pipes we were connecting to a box culvert. In profile and plan, the pipes appeared to connect, but in different pipe networks, C3D didn't actually make the connection, so it didn't split my culvert.
HP Z600 8 Gig RAM
Civil 3D 2011
Re: Pipe tee
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I knew somebody would come up with a workable solution. Thanks for the suggestions. Seems some aspects of C3D require more workarounds than others, especially pipe networks.
Civil 3D 2012
12gig RAM
NVIDIA Quadro 600
Re: Pipe tee
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Cansel - Autodesk Division
http://www.cansel.ca/
Re: Pipe tee
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Pardon my ignorance but wouldn't it have to be 3 pipes in the field attached to t tee fitting? Like in the the HDPE catalogs
hmm. per haps ADS has a c3d catalog?
I'm thinking null structure
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
Re: Pipe tee
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
We've had instances where we were tying a new 24" RCP pipe to an existing 96" RCP. Our detail showed them cutting a 30" hole on the upper half of the 108" to connect the 24" and grout in place. No structure. Also, similar connection to an 8' x 8' box culvert. Cut a hole above the perennial flow line and grout the pipe into it.
HP Z600 8 Gig RAM
Civil 3D 2011
