AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Pipe structure won't show up in profile view
- Highlight
- Email to a Friend
I've been having a problem with a pipe structure not showing up in a profile view. I have a single pipe network with everything (pipes and other structures) showing up in the profile when I select them, right-click, and click on "Draw Parts in Profile". Like I said, this works for all the other pipes and structures in the profile except one. When I select the structure individually and try to draw it into the profile, it still won't work. A friend told me to make sure that the structure is within the surface, and it is.
Any thoughts on this? I'm using AutoCAD Civil 3D 2011.
Thanks.
Re: Pipe structure won't show up in profile view
- Highlight
- Email to a Friend
Hi hdn9298,
I don't mean to be simplistic, but a few things come to mind: Is the structure within the limits of the alignment/profile? If the structure has a different style than the others (an override), is that style configured to show in profile view? Also, if the alignment doubles back on itself, the software has been known to get confused on exactly which station the structure is at. If you want to send me the drawing, I can take a look.
Scott Kent P.E.
Senior QA Analyst II
IPG – Information Modeling
and Platform Products Group
Autodesk, Inc.
100 Commercial Street
Manchester, NH 03101
Infrastructure Collaboration Products
Autodesk, Inc.
- Highlight
- Email to a Friend
To add to Scott's suggestions: does the structure properties indicate the expected surface elevation?
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
- Highlight
- Email to a Friend
My guess is that the structure in question is at one end or the other of your alignment, and the alignment does not go beyond the structure.
Bill
- Highlight
- Email to a Friend
You can also check to see if the stc has a 'hidden' style override assigned in the profile view.
Profile View Properties dialog, pipe networks tab. Locate your stc and go to the last column. See if an override is assigned.
C3D 2012, RD 2012
Win 7 64, Core i7,
6 GB RAM, Quadro FX 1700
- Highlight
- Email to a Friend
Thank you, everyone, for the suggestions. It turns out that Mr. Bouza made the suggestion that solved the problem. The insert rim elevations were set too high, beyond my profile's scale. Thanks again, I was at a loss over what was happening, but now I know to check the elevations!
- Highlight
- Email to a Friend
HTH.
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
