• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Pipe network parts change to a default when data referenced into other drawing.
    1483 Views, 9 Replies
    12-21-2010 03:04 PM
    When creating my plan set, I need to data reference pipe networks into other drawings than that in which they were designed to show crossings in profile views or to separate out profiles into managable drawings. When I do this, if I have swapped a type-13 inlet for a 10' type R inlet or something during design, the data referenced pipe network will replace the 10' type R with a default inlet. Also if I have swapped a proposed 30" pipe for an existing 30" that have different styles, the data referenced pipe network will revert back to the proposed 30" pipe. Does anyone know how to make a data referenced pipe network reflect what is currently in the design drawing?
    Ryan
    Please use plain text.
    Valued Contributor
    Re: Pipe network parts change to a default when data referenced into other drawi
    02-10-2011 02:38 PM in reply to: ryanbanning2585
    I cannot find a fix.  Anyone else having this problem?
    When data reference in my pipenetwork the structures come in as something ther than the part they were specified in the source drawings
    Edited by
    Discussion_Admin.
    *Expert Elite*
    Joe-Bouza
    02-10-2011 05:43 PM in reply to: wdbar
    I'd check the data ref editor to confirm you are referencing the correct SD and DREF, then open and SR and get back to us
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    *Expert Elite*
    02-10-2011 08:43 PM in reply to: ryanbanning2585
    ryanbanning2585 and
    wdbar
    I think there are two different issues here.
    First one:
     If you have a network with Str A using Style A and Pipe A using Style A then DS it out to a new drawing everything comes in fine. Now go back and change the pipe base to Str B using style B and Pipe B using style B.
    When you go back to the drawing with the DS network you will have Str B using style A and Pipe B using Style A.
    The structures and pipes are updated but they use the styles that were originally assigned. This works great for 99% of Civil 3D data, but it stinks with pipe networks. The only way is to manually change the styles used to match the ones in the pipe base or delete and re-Data shortcut, but that's not feasible if you have already labeled networks.
    Ryan, you said you swapped a proposed 30” pipe for a 30” existing one. Are they in the same parts list? That can wreak havoc with DS if one pipe network is using two different parts lists. We use separate parts lists for existing & proposed.
    Second:
    Wdbar, you are having issues with the structures not matching even the first time you DS the network, right?
    I think I know what is going on there. If you send me a dwg with your parts list I can test it. (bruce DOT klug AT clark.wa.gov) We found out that it depends on the way the parts list was created originally might cause this issue. When I setup ours originally I added a rectangular ...... structure and then renamed it to Catch Basin, Type 1. I then added another structure with the same exact size parameters (24x24.....) and even though I renamed it Catch Basin, Type 2 C3D sees them as having the same part ID. This has been confirmed by Autodesk.
    Bruce
    Bruce Klug
    AutoCAD Expert Elite
    AutoCAD Civil 3D 2013 Certified Professional
    C3D 2013 (SP1)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    02-11-2011 07:54 AM in reply to: klugb
    Thanks Bruce. I'm not sure that I am following your terminology though. What do you mean by Str A? Yes, ours are currently in the same parts list because they are part of the same network and we are having to modify both at the same time (ie. We have to break a run of existing pipe to insert a proposed manhole poured in place over the existing pipe. We may have to look at two but that might take some planning to figure out how to make it work.
    Any thoughts on why an inlet created as a type-r with a style using a 10' type-r block and proposed layering would revert back to a type-13 combo inlet with that style, block and proposed layering in a sheet drawing that has the pipe network data referenced into it (instead of coming in as the type-r that it was designed to be)? Take a look at the attachment to my previous post. The type-r is xrefed from our base utility drawing that uses "dumb" blocks, but the type-13 combo is from the pipe network data reference that was designed as a type-r in the storm pipe base drawing.
    02-11-2011 07:55 AM in reply to: Joe-Bouza
    Joseph, could you clarify what SD, Dref and SR are refering to please?
    *Expert Elite*
    02-11-2011 08:24 AM in reply to: ryanbanning2585
    I was just being lazy, Structure A.
    I think your fine with the existing & proposed in one. The problems I have seen are when we layout a proposed network using the proposed parts list and then someone changes the parts list to existing and adds pipes or structures. When you Datashort cut it into another drawing you can only pick from one parts list at a time.
    I would need to have your parts list to test my theory on the switching inlets. I know how to test it and why it does it, but it's hard to explain.
    Bruce
    Bruce Klug
    C3D 2013 (SP1)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    New Member
    07-20-2011 10:37 AM in reply to: klugb
    Bruce,
    "When I setup ours originally I added a rectangular ...... structure and then renamed it to Catch Basin, Type 1. I then added another structure with the same exact size parameters (24x24.....) and even though I renamed it Catch Basin, Type 2 C3D sees them as having the same part ID. This has been confirmed by Autodesk"
    What did you do to fix this?
    I am having the same issue - they come in wrong when first DS.
    Rob
    *Expert Elite*
    07-20-2011 11:00 AM in reply to: robillg
    We now have completely built our own custom parts list starting in parts builder to meet our County standards (see image). This is not for the faint of heart! Depending on your comfort level and $ there are people that you can hire to do it.
    Before we did that I brought in each part with slightly different dimensions. I would keep the box the same 24x24, but one would have a different wall thickness or floor thickness. This worked but there is a limit to how many different combinations you can come up with.
    Bruce Klug
    C3D 2013 (SP1)
    C3D 2014 (Testing)
    Win 7 Pro, 64-bit
    *Expert Elite*
    03-01-2012 10:25 AM in reply to: klugb
    Working on my first big job in quite a while and ran into this issue. Thanks, Bruce, for showing me the way out of this 'wrong style in a DRef" nightmare I was having. I'd recalled seeing the issue before, but all my projects the last few years have had few, if any, of these structures. This job has ~100 and was not looking good to have to make sure each one displayed correctly.
    Jeff_M, also a frequent Swamper
