• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Accepted Solution
    Pipe in Profile going in the wrong direction
    283 Views, 13 Replies
    11-09-2012 11:50 AM
    I have the following situation:
    I have a pipe network (data shortcut) showing in the profile.
    The pipe network was designed from station 98+65 to 100+00.
    But the first pipe (from station 98+65 to 99+30) is shown going from station 99+30 to 102+60.
    The pipe has a lenght of about 65' and some how it is being projected incorrectly.
    Any ideas why its going in the wrong direction?
    The profile is shown going from right to left.
    See attached image.
    Thanks for your help.
    Windows 7 64-bit
    Civil 3D 2012 SP2
    Please use plain text.
    *Expert Elite*
    Re: Pipe in Profile going in the wrong direction
    11-09-2012 12:36 PM in reply to: henryosegueda
    Is there a curve in the alignment?  Is it possible that one end of the pipe is being projected to the wrong part of the alignment, but still perpendicularly projected?  I'd be interested in a screen shot of the plan.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Active Contributor
    11-09-2012 01:30 PM in reply to: troma
    There are no curves in the alignment.
    Attached is a plan and profile.
    *Expert Elite*
    11-09-2012 01:35 PM in reply to: henryosegueda
    I didn't really mean just curves; I mean any PIs, bends.
    I'm having a hard time with that plan, any chance you can turn off some layers and take a screenshot with just the alignment and the pipes?
    Active Contributor
    11-09-2012 01:49 PM in reply to: troma
    There are PI's and vertical bends.
    I hope the attched image makes it clearer to understand.
    Distinguished Contributor
    11-09-2012 01:54 PM in reply to: henryosegueda
    In your plan view (pipe profile 2.png), it appears their is a pipe network going up to the Northwest (assuming north is up) starting at 100+00.
    If I look at the NW end of that pipe, it would project perp to around 102+00 which corresponds to your profile view.
    Did you project the correct pipe onto profile?
    Also, if I may make a performance recommendation in case you have not run across it - I noticed in your first image that when you select an object you get sort of a dashed line highlight - if you change your previeweffect = 1, it will just use a thickended line sometimes drastically improving performance since it does not have to generate the dashing.
    -Bruce
    Active Contributor
    11-09-2012 02:08 PM in reply to: bruce.jordan
    On 'pipe profile 2.png' it does show an existing pipe going NW but you will notice that is does not show on 'pipe profile 3.png' becuase is not part of the pipe network.
    I show two different pipe networks.
    The dashed represent the existing pipe and the continuous represent the proosed pipe.
    I suspect that the profile from station 99+30 to 102+60 is projecting the existing pipe network perpendicular to it.
    Is there a way for it not to do that?
    Regarding performance, I will give it a try.
    *Expert Elite*
    11-09-2012 02:10 PM in reply to: henryosegueda
    I'm still having a hard time seeing what's what.
    In your plan, draw a line from your alignment at the station where the end of the pipe is being drawn to, to the actual end of the pipe.  See if that makes it any clearer why it is picking that station.
    11-09-2012 02:20 PM in reply to: henryosegueda
    hosegueda -
    In the Profile, can you check your pipe properties (highlight pipe and right-click selecting PIPE PROPERTEIS) of the pipe in question and just verify that the NAME IS what you expect.
    Also, highlight and right-click on your PROFILE GRID and select profile view properties - there is a PIPE NETWORK tab.
    Verify that the pipes you want to show have the DRAW column checked on, and those you do not want to show are unchecked.
    -Bruce
    Active Contributor
    11-09-2012 02:29 PM in reply to: bruce.jordan
    Here is another image with arrows pointing to where the pipe is in relation to plan and profile.
    The pipe is the correct one shown in profile when I click on PIPE PROPERTIES.
    And under PIPE NETWORK tab, I have the pipe checked to show on profile.
