• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    Pipe crossing pipe lable style
    197 Views, 3 Replies
    11-20-2009 08:12 AM
    I am working on a profile view currently and am having problems labeling crossing pipes. I have some pipes that cross the alignment and come into structures shown in the profile view. I have overidden the pipe style in the profile view properties dialog box to show the pipe coming into the structure (I used a pipe crossing pipe style). When I do this the pipe seems to become part of the structure and I cannot seem to find a way to label the crossing pipe in profile view. Does anyone know how to label a crossing pipe in profile view that is connect to a structure? I have attached a picture showing what pipe I would like to label. Any help would be appreciated.
    Thank you,
    Andrew Schieltz, E.I.
    C3D 2010
    Please use plain text.
    *Pro
    Re: Pipe crossing pipe lable style
    11-20-2009 09:43 AM in reply to: andrewschieltz4115
    We at Prein&Newhof label that pipe in our structure label along with the other inverts into the structure. A pipe label would not be used in this case. A profile view label could be used if only the pipe in question was to be labeled, and no structure label was to be used.
    Dan
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Valued Mentor
    11-20-2009 11:20 AM in reply to: andrewschieltz4115
    I agree with Dan. I don't think you can label this sort of connected-to-a-structure pipe separately, just within in the structure label itself. And even then, there are limitations. About the best you can do is have the structure label call out the pipe size, invert elevation, and IN or OUT flow direction. (There are many other parameters that can be called out, of course, but the point is they are all within the structure label, not a separate pipe label.)
    Active Contributor
    11-20-2009 12:58 PM in reply to: andrewschieltz4115
    Thank you for the help.
