• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    Joe-Bouza
    Accepted Solution
    Pipe Styles
    677 Views, 3 Replies
    03-23-2011 12:42 PM
    I can't believe I haven't encountered this yet. I have a drawing with a couple of profiles and some pipe networks. One alignment is collinear with the pipe network and another crosses the networks. I want to show the pipe crossing as well as the longitudinal on it companion alignment. If I set the profile setting for the pipe display to show the pipes crossing I don't get the longitudinal and if I try to assign the different style to the crossing pipes the plan view disappears. So, how should I set my styles to get a crossing pipe and a longitudinal in the same file?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Please use plain text.
    *Expert Elite*
    Re: Pipe Styles
    03-23-2011 01:11 PM in reply to: Joe-Bouza
    Create a style for the crossing display. Assign this style to the pipe's Style Override in the ProfileView properties Pipe networks tab.
    *Expert Elite*
    Joe-Bouza
    Re: Pipe Styles
    03-23-2011 03:32 PM in reply to: Jeff_M
    Perfect. I was lookig for something like that but couldn't see through my panic :smileyvery-happy:
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    Active Contributor
    Re: Pipe Styles
    07-19-2012 10:33 AM in reply to: Joe-Bouza
    This also helped me with a different problem I was having (so far at least).  I would change the pipe style to my XING pipe style, save and leave the drawing.  When I opened the drawing...all my xing's had changed back to a non-xing style!  I tried it with the override and so far the styles seem to stick.  This tip would have come in handy on another drawing long since gone now.  Thanks!
    Carl M. Fiorica, P.E., LEED A.P.
    Burkett and Wong Engineers
    3434 4th Ave
    San Diego, CA 92103
