• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Pipe Network without surface
    127 Views, 2 Replies
    11-21-2011 12:39 PM
    Can I create a profile of my pipe network with having to create a surface?
    Please use plain text.
    Re: Pipe Network without surface
    11-21-2011 04:58 PM in reply to: bgriffin291
    Yes,
    After creating your Pipe Network in Plan View, Edit the Pipe Network. Adjust the inverts and rim elevations to design. Create a profile view. Adjust the User Specified Height in Profile View Properties (Elevations tab) so that the pipes and structures will fit.
    Use Draw Parts in Profile to place the pipe network.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Valued Contributor
    11-22-2011 06:40 AM in reply to: tcorey
    Thanks.
    I've never used the Create Profile View.  I always just used the Create Surface Profile.
