• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Pipe Network Structure Label Layers
    122 Views, 6 Replies
    01-08-2013 09:19 AM
    I have a pipe network created that is shown in multiple drawings.  I created labels for the structures showing Rims and Inverts.  Does anyone know how to put the Rim info on a different layer than the Invert info?  Right now the label has 3 different components...I feel like there has to be a way to put each component on different laters...anyone have thoughts?
    thanks!
    Please use plain text.
    TRogers
    Re: Pipe Network Structure Label Layers
    01-08-2013 09:39 AM in reply to: accarr03
    3 different label styles on 3 different layers.  Why would you want to do this?
    If the issue was resolved by this method, please click on "Accept As Solution"
    *Civil 3DJ*
    Todd Rogers
    Visit my blog here.
    01-08-2013 09:41 AM in reply to: accarr03
    Don't think so, sorry.  Each component can be different colours, but not layers.  You may need to make different labels to achieve what you need.  Wish they would allow componant layers though.
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Active Member
    01-08-2013 09:45 AM in reply to: TRogers
    Ok, thanks.  That's what I was afraid of.  I have a plan that shows the grading of the site and another plan that shows the pipes and structures.  I want to show the Rim elevations on both plans, but the Invert elevations only on the utility/piping plan.
    Do you know if I use data shortcuts to bring the pipe network into my Grading plan, can I add structure labels to that plan?  Right now I have a base file with the structures and labels that is XREFed into both plans.
    Valued Mentor
    Valued Mentor
    sjg
    01-08-2013 10:10 AM in reply to: accarr03
    Yeah I would suggest data referencing your network into each drawing and then label your structures, this way you get more flexibility on how and what you label for each drawing.
    Steve Goessling
    Land Consultants
    Civil3D 2012 (Service Pack 2.1)
    Windows 7, 64 bit
    Intel i7 2600 @ 3.40Ghz
    16 GB RAM
    Nvidia Quadro 600
    01-08-2013 10:36 AM in reply to: accarr03
    What version are you working in?  I think since 2010 or 2011 you don't need to data shortcut them in if you are just adding labels.  You can just add the label to the structure in the x-ref.
    So freeze off the labels that are in the x-ref and add new labels in the Grading Plan showing just the rim elevation.
    Active Member
    01-08-2013 11:11 AM in reply to: troma
    I'm in Civil 3D 2012.  You're right, I don't need to data shortcut the structures in.  That's good to know...thanks!
