• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    Pipe Network - Crescent Road - Profile View
    588 Views, 8 Replies
    07-30-2011 02:07 PM
    Hi folks,
    If I have a Crescent Road (P - shape) where the Alignment returns to itself, when i draw pipe network parts in profile, the pipe network gets drawn wrong, ie. the tie-in structure at the intersection is drawn at the wrong station.
    My understanding is that the structures will get drawn at the station closest perpendicularly to the alignment, so the structure is going to the end station as opposed to the beginning simply because the end segment of the alignment is closer.
    Is there any way to make a structure use a different perpendicular station (without shortening the alignment)?
    What is the best practice for this scenario?  I don't want to move alignment or structure.
    C3D 2010, Windows 7 64 bit.
    THANKS
    Please use plain text.
    *Expert Elite*
    Re: Pipe Network - Crescent Road - Profile View
    07-31-2011 05:44 AM in reply to: kevinjackman
    I believe your best way out of this is to use two alignments. (e.g., Sta 0+00 to Sta 10+50, Sta 10+50 to Sta 12+85)
    Bill
    07-31-2011 11:16 AM in reply to: wfberry
    Two Alignments doesn't solve my problem.  Same result.
    When you 'draw parts in profile', the pipes are drawn in profile, referencing the station of the grid chosen, and of course the grid is a function of the aligment.
    I still get a pipe drawn in profile that stretchs from one end of the profile to the other, overlapping other pipes and structures.
    08-01-2011 05:41 AM in reply to: kevinjackman
    This can be done with a single alignment.  When laying the network out, just use the station-offset transparent command ('so).  Then when placing pipe ends or structure locations, you will see the glyph that will ensure you have the correct station.
    Scott Kent P.E.
    Senior QA Analyst IMPLG
    Autodesk, Inc.
    Scott Kent P.E.
    Senior QA Analyst II
    Infrastructure Collaboration Products
    Autodesk, Inc.
    100 Commercial Street
    Manchester, NH 03101
    08-01-2011 06:59 AM in reply to: scottkent
    Thanks Scott - maybe I haven't articulated this well.
    I can layout the network no problem.
    The issue is that on a Crescent, where a road ties back to itself, the pipe network is drawn in profile incorrectly.
    See red pipe in attached drawing.
    Active Contributor
    08-01-2011 07:34 AM in reply to: kevinjackman
    This is a software quirk, IMO. I would remedy this by using display/design alignments. In short you would need two additional  alignments that would not be displayed in plan view. The first alignment could run from sta:1+000 to sta:1+100 and the second from 1+100 to the end. Use station control to start the second alignment at the proper sta. Then you would need to align your profile views side by side and create styles that would make them appear seamless. I have found no other way around this, hopefully that works for you. Good luck,
    08-01-2011 08:26 AM in reply to: kevinjackman
    Thanks for the drawing Kevin.  It must be me not understanding things.  The pipe in profile is doing exactly what it is doing in plan.  In plan view, the red one (Pipe 17) is flowing from structure 18 at STA 1+301.646 to structure 11 at STA 1+063.439.  In profile, it does the same - but looks 'strange' because it bypasses a whole bunch of structures and pipes; but that is technically correct.
    Now, if you mean that you want 'the tie in structure' (Structure 11) to be stationed at the end of the alignment, then you will have kind of the opposite scenario: Pipes 10 and 11 will extend in profile to the end, and that will look even more confusing.  Note that if this is your intent, notice that your alignment ends a little short of the structure.
    Sorry if I am not getting it - you can call me if you want.  603-621-3344.
    Scott
    Scott Kent P.E.
    Autodesk, Inc.
    Member
    11-05-2012 07:23 AM in reply to: kevinjackman
    Hi Kevin,
    I was wondering if in the end you found a good solution? I am working on a project with this exact problem.
    Nathan
    11-05-2012 07:30 AM in reply to: nduimering
    Hi Nathan,
    I acheive the best result by making two alignments and two profile views.
    You will have to patch the two profile views together.
    Kevin.
