AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Pipe Label Bug
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I’m having a problem with my pipe labels when I xref them into other drawings. The attached file has my pipe label in it (RFE Boat-SD). The label has a block in it and all the layers within the block are on the 0 layer. When I look at the attached drawing, everything looks fine, the boat inherits the properties of the label (the label style is set to display on the C-STRM layer). However, when I xref the drawing into another drawing, the boat labels inherit the properties of whatever layer is current in that drawing. More annoyingly, each time I reload the xref the label will take on whatever new layer is current at that time, even regardless of what layer the xref is on. If anyone can shed any light on the situation or offer a solution other than creating a block for each layer I want the boat to display as (which is my current workaraound), then please let me know.
Thanks!
Civil 3D 2013
64-bit HP Desktop - HP Z420
Intel Xeon CPU E5-1620 0 @ 3.60 GHz
24GB RAM
AMD Radeon HD 6570
Windows 7 SP1
Re: Pipe Label Bug
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I don't have 13, but sounds like a VISRETAIN variable change is in order.
Re: Pipe Label Bug
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Excellent question that I, too, have observed. Not always, but occasionally. Sometimes it's the tic block for stationing, sometimes it's dimension arrowheads. Most of the time, everything is fine.
My workaround, and it's not a solution, is to create a toobar icon that, when clicked, changes the current layer to zero, saves the drawing, then closes the drawing. I use that everytime I close a file. In that way, opening the file or plotting the file from the sheet set manager gets me the results I expect.
I, too, am anxious to hear the solution to this perplexing occurance.
Re: Pipe Label Bug
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Cansel - Autodesk Division
http://www.cansel.ca/
