• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Pipe Invert Labels in Profiles
    469 Views, 6 Replies
    10-15-2012 06:07 AM
    I am trying to place my pipe invert labels at the actual point of the invert. When using the pipe label style composer, I have selected Anchor Point to be "Bottom Inner Diameter". Why is it that the label style still imports into the center of the pipe? No matter which anchor point I choose the label still inserts to the middle of the pipe. Is there a hidden setting that I am missing?
    Thanks.
    Bill H.
    Civil 3d 2013 under development
    Win 7 Pro 64-Bit - Dell T1600
    Intel Xeon 3.30Ghz
    8Gb RAM
    Civil 3D 2013
    Please use plain text.
    Re: Pipe Invert Labels in Profiles
    10-15-2012 11:04 AM in reply to: dbill2508
    I don't think there's a way around it.  When you anchor to inside bottom, the label moves to the invert, but the grip remains at centerline. It sucks because the leader, if used, will point to the centerline.
    Tim Corey, Owner
    Delta Engineering Systems
    Redding, CA
    Autodesk Authorized Value-Added Reseller
    Joe-Bouza
    10-15-2012 05:22 PM in reply to: dbill2508
    The x & y offset and probably an expression should get you where you want to be
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Valued Mentor
    10-16-2012 12:29 PM in reply to: dbill2508
    Are you trying to label the pipe inverts at the ends of the pipes? Or sonewhere in between?
    10-17-2012 03:06 AM in reply to: dbill2508
    Correct, I am trying to label them at the ends of the pipe. We used to use a multileader with a spline leader and invert elevation. But now when you use the style in dragged state the leader only stays in the center of the pipe.
    Intel Xeon 3.30Ghz
    8Gb RAM
    Civil 3D 2013
    Valued Mentor
    10-17-2012 05:46 AM in reply to: dbill2508
    If you are trying to label them at the pipe ends, there must be a connecting structure between them. (Perhaps a Null Structure, at the very least.) Why not label the structure? The labels will appear at the pipe ends automatically.
    10-17-2012 07:23 AM in reply to: castled071049
    Visual time. Red leader is what I get. Brown Leader is what my company wants.
    Attempting to use the offsets and expressions gets the text to move but not the dragged state leader connection, unless I am doing them wrong.
    The work around currently being used is to hide the dragged state leader and then add our own after placing the text.
    Intel Xeon 3.30Ghz
    8Gb RAM
    Civil 3D 2013
