AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Perpendicu lar pipe in structure profile
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hi all,
I have a pipe network and a profile for it. Some of the structures have 2 inlet pipes. The pipe system more of less goes down a road, so every now and then there is a cross pipe into a structure. I have masking turned on under the structure style->profile setting. I want to see the cross pipe, so I found on here that all I need to do is under structure style->view direction (profile)->make Structure Pipe Outlines visible. I did that and still no cross pipe shows up. If I turn the masking off it is there. I must be missing a setting or something. Anybody have an idea what it could be?
Thank,
Wilson
Dell T3600
Windows 7 x64
Autocad Civil 3d 2012
Re: Perpendicu lar pipe in structure profile
- Highlight
- Email to a Friend
Do you have ALL the pipes in the network in that one profile view? Or just the ones along the alignment? (i.e. the main trunk line.) If you have all of the pipes, you need to delete from the profile view the intersecting laterals . In that way the structures will be able to show the intersecting pipes as ellipses.
- Highlight
- Email to a Friend
i have a style set just for the xing pipes and i set that as a override in the profile properties. as far as the masking it has to be turned off to show the xing pipes.
Just a CAD Manager for a Civil Engineering firm...
Win 7 pro 12gb
NVIDIA Quadro 2000
LDD 2009
C3D 2012
- Highlight
- Email to a Friend
Thank you so much, it worked!
- Highlight
- Email to a Friend
I have masking turned on for structures in profile, and in profile view properties I uncheck the connected pipe and the oval appears.
