• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    Perpendicular pipe in structure profile
    194 Views, 4 Replies
    01-28-2013 04:10 AM
    Hi all,
    I have a pipe network and a profile for it.  Some of the structures have 2 inlet pipes.  The pipe system more of less goes down a road, so every now and then there is a cross pipe into a structure.  I have masking turned on under the structure style->profile setting.  I want to see the cross pipe, so I found on here that all I need to do is under structure style->view direction (profile)->make Structure Pipe Outlines visible.  I did that and still no cross pipe shows up.  If I turn the masking off it is there.  I must be missing a setting or something.  Anybody have an idea what it could be?
    Thank,
    Wilson
    Dell T3600
    Windows 7 x64
    Autocad Civil 3d 2012
    Please use plain text.
    Valued Mentor
    Re: Perpendicular pipe in structure profile
    01-28-2013 05:51 AM in reply to: wfisk
    Do you have ALL the pipes in the network in that one profile view? Or just the ones along the alignment? (i.e. the main trunk line.) If you have all of the pipes, you need to delete from the profile view the intersecting laterals . In that way the structures will be able to show the intersecting pipes as ellipses.
    Valued Contributor
    sturner7277
    01-28-2013 06:52 AM in reply to: wfisk
    i have a style set just for the xing pipes and i set that as a override in the profile properties. as far as the masking it has to be turned off to show the xing pipes.
    -Sean
    Just a CAD Manager for a Civil Engineering firm...
    Win 7 pro 12gb
    NVIDIA Quadro 2000
    LDD 2009
    C3D 2012
    Member
    01-29-2013 09:20 AM in reply to: castled071049
    Thank you so much, it worked!
    Distinguished Contributor bf
    05-16-2013 03:31 PM in reply to: wfisk
    I have masking turned on for structures in profile, and in profile view properties I uncheck the connected pipe and the oval appears.
