• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    sadekcivil
    Paste to Original Coordinate Issue
    1121 Views, 7 Replies
    12-24-2011 01:32 AM
    Hello There,
    I have some problem with paste to original coordinate that it appears as grey in right click as shown in attached file but it can paste from ribbon.
    Any help will be appreciate.
    Thank you.
    Please do not forget approve as solutions and Points
    to Remember Please Accept as Solution and Kudos Please
    Please use plain text.
    *Expert Elite*
    neilyj
    Re: Paste to Original Coordinate Issue
    12-24-2011 02:27 AM in reply to: sadekcivil
    Happens to me in both 2011 and 2012 versions - no known fix.
    I put the command on a toolbar (could try quick access) then its always available
    neilyj
    (No connection with Autodesk other than using the products in the world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    *Expert Elite*
    Joe-Bouza
    12-24-2011 07:10 AM in reply to: sadekcivil
    I'm wblock, insert guy.
    I think though, when I have used it,  it greyed out when I specified a base point. It worked if I only copied and pasted to original coords.
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    *Expert Elite*
    BrianHailey
    12-24-2011 02:28 PM in reply to: Joe-Bouza
    I just tried it both ways (copy and copy w/ basepoint) and it made no difference. I was able to paste to original coordinates in both cases so I don't think that may be the cause. I have seen this as well and whenever I see it I just use the command off the ribbon.
    If I remember correctly, when I investigated this at one point, the paste to original coordinates command on the right click menu in the CUI had an extra hot key (you know, those underlined letters in a menu) and when I removed that it worked correctly. It's been a while so I may have be mistaken.
    sadekcivil
    12-24-2011 11:32 PM in reply to: sadekcivil
    I figered out the solution try to select any object even autocad or civil object and right click and clipboard and then you will get paste to original cooridinate appears and you can use it.
    If anyone get this solution please tell me.
    Thank you.
    Valued Contributor
    11-08-2012 06:30 AM in reply to: sadekcivil
    Dear Autodesk,
    PLEASE FIX THIS ISSUE.
    It has gone on way too long.  This is incredibly annoying!
    Sincerely, CAD users everywhere. :smileyhappy:
    Valued Contributor
    11-08-2012 09:59 AM in reply to: sadekcivil
    I have seen this issue when trying to paste into the same drawing of one with the same name, but only then.  Oddly, "paste" will work and ask you for coordinates.
    Conan Witzel
    Valued Contributor
    11-08-2012 10:11 AM in reply to: witzel
    I'm sure many users have noticed patterns and have a few work-arounds.  It should just work:smileyfrustrated:
