AutoCAD Civil 3D
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Parcel error
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
54 Views, 5 Replies
11-30-2004 03:08 PM
I've got a drawing with some parcels in it. I noticed that the styles weren't being applied correctly. (i.e. I can change the parcel style, but the style is not updated in modelspace). Then I browse the Toolspace parcels list and scroll down through the list. It seems to scroll through the top part of the list OK, but when I get to a certain point Civil3D locks up, the task manager shows 100% CPU usage, and I have force Civil3D to shut down.
I'm using Civil3D 2005 and I've been able to replicate this error on a couple of computers.
Obviously there's something wrong with the dwg. I've tried an audit, but no errors turned up.
Now it's not a great problem because the parcels were imported from a LD2005 project, so I can always import them again. However, if there was no LD2005 project then it'd be a real problem.
So there's 2 questions:
1. How can I get my drawing working correctly?
2. How can I safeguard data in case of a drawing crash? If a drawing gets corrupted then you potentially loose all of your design data. My error was not immediately apparent so a good backup system/policy may not have beaten it.
I appreciate any thoughts on either of these issues.
Michael
Michael
Michael
Civil3D 2012
HP Elitebook 8560w
Core i7-2820QM (2.3-3.4GHz)
nVidia Quadro 2000M 2GB
www.foxsurvey.co.nz
Civil3D 2012
HP Elitebook 8560w
www.foxsurvey.co.nz
*Chakri Gavini
Re: Parcel error
Options
- Highlight
- Email to a Friend
11-30-2004 04:24 PM in reply to:
Buzz123
Michael,
About parcels not showing up with right styles:- Probably those lot lines
are shared by adjacent parcels. If this is the case do following:
In prospector right click on the parcels collection (a node above the parcel
of your choice) and choose "Properties..." this will bring up the site level
parcel group properties. In the composition tab bottom most list box
presents styles used in this collection. Highlight the style that show on
top and move up in display order.
About locking up - i am not sure what is happening, perhaps i could debug
that dwg if it is possible for you to send it across to me.
Hope this helps
Chakri
chakravarthy.gavini@autodesk.com
"Buzz123" wrote in message
news:29060244.1101856169818.JavaMail.jive@jiveforu m1.autodesk.com...
beaten it.
> Thanks
> Michael
*Karl Fuls
Re: Parcel error
Options
- Highlight
- Email to a Friend
11-30-2004 07:08 PM in reply to:
Buzz123
I've had the same locking up problem with alignments imported from LDT.
Any type of edit would bring my system to its knees. I started a new
drawing and built the alignments from plines brought in from the LDT
drawing or from the centerline geometry and no problems so far.
Karl Fuls PLS
Autocad AEC Training and Consulting
Autodesk Discussion Group Facilitator
Chakri Gavini wrote:
> Michael,
> Hope this helps
> Chakri
*Angel Espinoza
Re: Parcel error
Options
- Highlight
- Email to a Friend
12-06-2004 04:05 PM in reply to:
Buzz123
In regard to your question about how to safeguard your data. Do not forget
that LandXML is considered by other software as their archive system. It's
prior proper and timely use can save you from lost information.
Autosaves (something LDt did not use) can now also play a significantly more
vital role.
Angel Espinoza
KETIV Technologies
beaten it.
> Thanks
> Michael
Re: Parcel error
Options
- Highlight
- Email to a Friend
12-08-2004 08:22 AM in reply to:
Buzz123
when creating parcels using the very basic line and curve commands, the command needs to be reinitiated prior to creating another parcel. it is ok to keep drawing lines if you are still defining the same parcel.
Scott Wolfe
Scott Wolfe
Re: Parcel error
Options
- Highlight
- Email to a Friend
12-26-2004 10:03 PM in reply to:
Buzz123
The parcel manager crashes consistently when trying to edit or create parcels. This is unworkable as far as I'm concerned, becasue of the lost files and lost time redoing work from scratch.
