AutoCAD Civil 3D
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
*scott mceachron
Parcel Numbers
Options
- Highlight
- Email to a Friend
236 Views, 5 Replies
02-26-2004 12:52 PM
When I create a site, I want it "named" as opposed to "numbered." That much
I've figured out. However, when I set defaults for parcel numbering within
my site, I can't find a way to change the default numbering scheme - I want
to start numbering at Lot "1" and move up incrementaly from there.
Where/how can I change the default numbers for my parcels?
Why is it that once I physically change a parcel number, my parcel table
does not reflect my new numbers?
I've installed SP1, why does the Create ROW command not show up in my menu?
Having all sorts of fun!
scott
scott mceachron
total cad systems - dallas
*scott mceachron
Re: Parcel Numbers
Options
- Highlight
- Email to a Friend
02-26-2004 02:20 PM in reply to:
*scott mceachron
Got it, right click on the site and change numbers there - but why MUST I
have a number for a site? And if I split of a 50' ROW why does it
automatically number them - can't they be names as well?
mho,
sm
scott mceachron
"scott mceachron" wrote in message
news:403e5c7b$1_3@newsprd01...
much
within
want
menu?
> scott
> scott mceachron
Re: Parcel Numbers
Options
- Highlight
- Email to a Friend
03-01-2004 08:17 AM in reply to:
*scott mceachron
scott mceachron
total cad systems - dallas <----- hey Scott is there something you haven't told us.... lol
*scott mceachron
Re: Parcel Numbers
Options
- Highlight
- Email to a Friend
03-01-2004 08:51 AM in reply to:
*scott mceachron
*Dave Simeone
Re: Parcel Numbers
Options
- Highlight
- Email to a Friend
03-04-2004 02:04 PM in reply to:
*scott mceachron
Hi Scott
There are a couple of options:
To change parcels that have already been drawng, use the "renumber parcels"
command. This will allow you to renumber a group of parcels (ie, drag a line
from the first to the last and it'll renumber based on start point and
increment).
To set the default starting number and increment...
Go to the Prospector data tab, select the Site that you are going to add
parcels and right click/properties. (by default this would be "Site 1"). Go
to the "Numbering" tab:
Per Help...
Parcel: Next Automatic Area Counter
Specifies the starting number for new parcels to be created in the site. The
numbering is incremented with creation of new parcels.
Note Setting this range sufficiently above the manual range will help avoid
collisions while renumbering manually.
Parcel: Next Manual Area Counter
Specifies the default starting number for renumbering parcels in the site.
This value can also be edited in the parcel Renumbering dialog box.
Cheers
DAS
much
within
want
menu?
> scott
> scott mceachron
*Daniel Philbrick
Re: Parcel Numbers
Options
- Highlight
- Email to a Friend
03-08-2004 05:19 AM in reply to:
*scott mceachron
Scott,
The Sites do not get a "Number". If you let the software default the Site
Names, then it will create Sites names similar to; Site(1), Site(2),
Site(3), etc. However, these are really names since you cannot renumber
sites or set the numbering seed value. If you right click on the Site you
are changing the name of the Site.
However, the parcels that are created within a Site do get both a Name and a
Number. The parcel numbering is a setting that you can establish when you
create the site. To do this, go to the Settings tab, expand the Parcel
node, expand the Commands Node, select Create Site and Edit Command
Settings. On the dialog that appears, you can set the starting number and
increment for the Automatic and Manual number. This will set the value for
any site that will be created. The Automatic number is the number used when
you add new parcels. The Manual number is the number when renumbering.
Therefore, initially you may want to set the Automatic number so an
arbitrarily high number so there will not be number conflicts when you
choose to go back and renumber.
You can also change the default numbers on Site that have been already
created. To do this, select the Site from Prospector, select Properties and
Go to the Numbering Tab.
The parcel tables have a static mode. I suspect that the parcel table you
created is in Static mode. If you select the table, rt click you can
either "Update content" or change it to a dynamic table. Either of these
operations should update the parcel numbers.
When you run the CreateROW command, it creates new parcels. Therefore, it
will use the "Automatic" numbering to establish a number for the new
parcel(s). Any that you renumbers, should retain the new number. However,
if you split a parcel in half that has been renumber, you cannot control
which parcel will retain the original number. Therefore, it may look like
is was renumber. Yes, they can be named. The name is template that you can
create in the Parcel Style. Therefore, you can setup the parcel name to
contain the parcel number.
Lastly, the reason you are not seeing the CreateROW command is because you
still have the compile menu files from the pre-SP version. You need to
delete those files and restart Civil 3D in order to get the updated menu.
See the Readme for the location of these files.
Daniel Philbrick
ISD Civil Development
much
within
want
menu?
> scott
> scott mceachron
