• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Parcel Labels COunterclockwise
    134 Views, 6 Replies
    01-24-2013 11:28 AM
    Currently running C3D 2012 SP2
    SETTINGS -> PARCEL -> COMMANDS -> AddParcelSegmentLabels -> Default Options, change to COunterclockwise.
    Anyone get this to work? When adding multiple labels it shows default as <COunterclockwise>: but when I hit enter it labels as CLockwise?!??! If I type in CO it labels properly.  Have to type in CO every time.
    Also, can someone check if it is fixed in 2013?
    Please use plain text.
    Valued Mentor
    Re: Parcel Labels COunterclockwise
    01-24-2013 12:27 PM in reply to: gbondoc
    It's not showing the default as COunterclockwise. It's telling you that if you want to make it label COunterclockwise, you need to type in "CO", otherwise it will label it Clockwise. You might check the commands to see if you can change the default setting to counterclockwise.
    01-24-2013 12:49 PM in reply to: gbondoc
    Possibly  there is a different default setting for single segment and multiple segment?
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    01-24-2013 01:14 PM in reply to: castled071049
    Not sure you are following my dilema.  Let me try to explain better.  If you change the default to counterclockwise.  When you label, it doesn't label them counterclockwise even though the default is set to that.  What is the purpose of having a default setting that doesn't stick?
    I havent seen a specific setting for single segment vs. multiple.
    IanMcClain
    01-24-2013 01:49 PM in reply to: gbondoc
    I'm seeing the same thing. It appears to label clockwise regardless of the default in settings. The only way to get muliple labels coming in counterclockwise is to type CO during the command prompt. Seems like you found a bug.
    -Ian McClain
    (running C3D 2012 sp3, Win7 64bit)
    01-24-2013 02:36 PM in reply to: IanMcClain
    Thank you Ian for verifying. Can someone verify if still the same in 2013?
    Main reason I'm interested is that I want the labels to default inside the parcels. Just rtying to streamline production. My label styles are set to label above the line/curve.  I would hate to have to go through ALL of our label style to switch them to label below the objects.
    01-24-2013 03:29 PM in reply to: gbondoc
    Same thing in 2013.
