AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: PNEZD file import issue.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Something similar to that was tried, but it came with the same error.
My descriptions are not importing still.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Can you attach the file?
(running C3D 2012 sp3, Win7 64bit)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Which file? I had posted images of the .txt file and the import settings.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OK, then as Ian and someone else has asked, if you could post the file (or at least the first 10 lines of it) I'm sure someone could figure this out. And by 'the file', that means the actual text file, not an image of it.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
OK, I just used the exact procedure I described before and the points come in fine. If you are keeping the elevation column in the point file format style, then both the original and your new will fail because the values are not numbers. By choosing the <not used> type for the elevation column it ignores these values. This is the file you just posted imported using doing just this.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Ok, just remove the quotes. When I said do a find and replace "<null>" with "0", I meant replace/use what was between the quotes.
Just for future refrence, when importing point files C3D doesn't like special characters. For instance if you had a description like TREE 10" OAK it would be truncated to TREE 10. For some reasone quotation marks end a description or in your case, skip the field entirely.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Good morning,
And thank you for responding. I replaced the "0" for 0 and the descriptions came in. So, if my point file has the " or any other special character in any field, it will void some of the fields?
My description column didn't have special characters.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
You had two " characters, one before and one after the 0. The first one truncated the elevation field, and the second truncated the description field. I don't know why those symbols do that, but they have always done it since I have been using autodesk software. It probably served some purpose in earlier versions.
