• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    PDF viewport layer control
    190 Views, 2 Replies
    03-07-2012 09:25 AM
    If you have more than one PDF overlay, you might put them on separate layers.  Generally speaking in this case, the PDF extents overlap so when i plot different sheets, I would want only a single PDF to be visible.
    So, my first thought was to freeze the layers of unwanted PDFs in the viewport.  Except, once i did that, nothing happened.  So, i guess i have to manually freeze the layer when plotting each sheet?  I then can't publish the layouts as the appropriate PDF's won't be visible.
    Anyone have ideas?
    Kevin
    Please use plain text.
    *Expert Elite*
    sboon
    Re: PDF viewport layer control
    03-07-2012 12:13 PM in reply to: KevinSpear_PE
    Valued Contributor
    03-07-2012 12:16 PM in reply to: sboon
    If they were used all at the same scale, that would work. I have 2 at one scale and 3 at other scales.  Ironically, the 3 at the larger scale aren't a matchline scenario. But more of a turn of the head to focus on another area of the site.
    Thanks for the reply! Good thought about clipping.  Had slipped my mind.
    Kevin
