• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Civil 3D
    Active Contributor
    sbd123
    PDF files
    190 Views, 4 Replies
    11-03-2012 12:59 AM
    Is it possible to vectorize native PDF files within the AutoCAD 2013 environment. If yes how? Sample PDF file attached.
    Please use plain text.
    *Expert Elite*
    Re: PDF files
    11-03-2012 02:23 AM in reply to: sbd123
    you can attach the PDF, then scale it to the scale you want/need, and then use object snaps to draw geometry above of the PDF. That's the way how you can do it with plain AutoCAD.
    There is no way I know to get it vectorized automatically without any application for vectorization.
    One of these options may be >>>Autodesk Raster Design<<<, but I have not played with that for a long time, so I don't know how it works with vector-PDFs. Also there are a lot of vectorization-software out in the www, search for it.
    Sorry, - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    *Expert Elite*
    neilyj
    Re: PDF files
    11-03-2012 02:47 AM in reply to: sbd123
    you would be better requesting the cad files although some companies are very reluctant to supply these.
    Even if you did vectorise the pdf it would only be in 2d so may not be of much use anyway
    neilyj
    (No connection with Autodesk other than using the products in the world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    Valued Mentor
    TerryDotson
    Re: PDF files
    11-03-2012 05:12 AM in reply to: sbd123
    While many PDF files need to be vectorized, the PDF file in your example contained vectors and can easily be imported.  Click here to download your file imported by DotSoft's ToolPac product which also contains a decent automatic vectorizer in the event it had been image based.  Vectorization is far from perfect even with the most expensize products and unless it's changed recently, Raster Design won't extract the images from the PDF anyway.
    However, "neilyj" makes a good point about quality.  The results of all PDFs have been flattened and their coordinate precision has also been reduced.  Anybody that designs on top of an imported PDF is asking for big trouble.
    Lastly, if you underlaid this and attempted to trace, it could take days when it could be done in a single minute.  Any firm that would do that and charge by the hour should be run out of town.
    *Expert Elite*
    antoniovinci
    Re: PDF files
    11-03-2012 05:23 AM in reply to: sbd123
    As mentioned, you cannot directly.
    With free tools, here's my 2 cents:
    1. convert your PDF to raster image with "PDF-X CHANGE VIEWER"
    2. vectorize the raster automatically with "WINTOPO"
