01:47 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello Everyone,
So a little background, I am using the overlay mill and level subassembly to generate contours for a mill and resurface. The style of the surface is .2 contours, im sure if I was using a higher contour interval the lines would smooth out but I have to use the .2 interval. What would be the best way to smooth these out? I have played around with many of the options in this subassembly and cant seem to generate smooth contours. I am debating to use a different subassembly and maybe just go with a superelevation one that I can use a profile so that I can manually tweak the gutters.
Nick
