• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Tim Duzan
    Osnap Mouse Button
    91 Views, 3 Replies
    04-27-2005 07:26 AM
    I've posted this in the AutoCAD.customization
    group, but still wanted to know if anyone has their mouse to have an osnap
    button programmed to pop up? If so, what is the direction to get it keyed
    in?
    Tim Duzan
    Jones &
    Boyd, Inc.
    LDT 2005 & Civil 3D
    Please use plain text.
    *Bill Farley
    Re: Osnap Mouse Button
    04-27-2005 08:31 AM in reply to: *Tim Duzan
    style="WIDTH: 100%; mso-cellspacing: 0in; mso-padding-alt: 0in 0in 0in 0in"
    cellSpacing=0 cellPadding=0 width="100%" border=0>
    style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0in; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0in; PADDING-BOTTOM: 0in; BORDER-LEFT: #d4d0c8; WIDTH: 433.5pt; PADDING-TOP: 0in; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent"
    width=578>
    style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0.75pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #d4d0c8; PADDING-TOP: 0.75pt; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent"
    vAlign=top>
    border=0>
    style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0.75pt; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0.75pt; PADDING-BOTTOM: 0.75pt; BORDER-LEFT: #d4d0c8; WIDTH: 375pt; PADDING-TOP: 0.75pt; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent"
    width=500>
    style="FONT-SIZE: 10pt; COLOR: #000066; FONT-FAMILY: Arial">Side
    button mouse customization for OSNAP menu
    style="FONT-SIZE: 10pt; COLOR: #000066; FONT-FAMILY: Arial; mso-fareast-font-family: 'Arial Unicode MS'">
    style="FONT-FAMILY: 'Arial Unicode MS'">
    style="DISPLAY: none; mso-hide: all">
    face="Times New Roman">
    style="BORDER-RIGHT: #d4d0c8; PADDING-RIGHT: 0in; BORDER-TOP: #d4d0c8; PADDING-LEFT: 0in; PADDING-BOTTOM: 0in; BORDER-LEFT: #d4d0c8; PADDING-TOP: 0in; BORDER-BOTTOM: #d4d0c8; BACKGROUND-COLOR: transparent">
    class=moduletextlarge1>
    style="FONT-SIZE: 9pt; FONT-FAMILY: Arial">If you have a mouse with
    side buttons and would like to make one of these side buttons pop-up
    your OSNAP menu (instead of having to hold down the SHIFT key and
    right-click) try this:
    style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">First go
    to the Windows Control Panel, double-click the mouse settings icon.
    If you have the correct mouse driver installed, you should be able
    to assign functions to every button on your mouse. Assign the button
    that you would like to use for OSNAPS as F12 ( since this funciton
    key is not used for anything else ).
    style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">Open
    AutoCAD and go to the Tools pulldown menu, choose Customize, then
    Toolbars.
    style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">On the
    Commands tab, click User-defined. On the top right, drag and drop a
    User-Defined Button out of the dialog box. This just made a new
    button and toolbar.
    style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">Right-click
    on the new button and choose Properties.
    style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">Name the
    button something, like OSNAPS. Look for ^C^C in the Macro text
    field, and type
    style="FONT-SIZE: 9pt; FONT-FAMILY: Arial">$p0=SNAP $p0=*
    style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">or cut and
    paste that from the Acad.mns file.
    style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">The string
    should look like the following:
    style="FONT-SIZE: 9pt; FONT-FAMILY: Arial">^C^C$p0=SNAP $p0=*
    style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">Select the
    Close button. Next, go to the Tools pulldown menu, choose Customize
    --Keyboard. Under Categories look for Toolbar1 Toolbar. If you have
    the right toolbar it should say OSNAPS under Commands. To the right
    under Press new shortcut key: pick the F12 button. Click the Assign
    button, Close, and try it.
    style="FONT-SIZE: 10pt; COLOR: black; FONT-FAMILY: Arial">The method
    above will also allow you to assign a Diesel macro function to your
    mouse buttons.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    in?
    Tim Duzan
    Jones &
    Boyd, Inc.
    LDT 2005 & Civil
    3D
    *Tim Duzan
    04-27-2005 11:08 AM in reply to: *Tim Duzan
    I have used that exact code in versions other than
    Civil 3D. F12 is now used to toggle on Dynamic, so that takes this option
    out.
    Any other suggestions would be greatly
    appreciated.
    Tim Duzan
    Jones & Boyd, Inc.
    LDT 2005 & Civil
    3D
    "Bill Farley" <farleywp at c dash b dot com> wrote in message
    href="news:4827394@discussion.autodesk.com">news:4827394@discussion.autodesk.com
    width=578>
    vAlign=top>
    border=0>
    width=500>
    with side buttons and would like to make one of these side buttons
    pop-up your OSNAP menu (instead of having to hold down the SHIFT
    key and right-click) try this:
    icon. If you have the correct mouse driver installed, you should
    be able to assign functions to every button on your mouse. Assign
    the button that you would like to use for OSNAPS as F12 ( since
    this funciton key is not used for anything else
    Toolbars.
    a User-Defined Button out of the dialog box. This just made a new
    button and toolbar.
    field, and type
    and paste that from the Acad.mns file.
    string should look like the following:
    the Close button. Next, go to the Tools pulldown menu, choose
    Customize --Keyboard. Under Categories look for Toolbar1 Toolbar.
    If you have the right toolbar it should say OSNAPS under Commands.
    To the right under Press new shortcut key: pick the F12 button.
    Click the Assign button, Close, and try it.
    method above will also allow you to assign a Diesel macro function
    to your mouse buttons.
    in?
    Tim Duzan
    Jones &
    Boyd, Inc.
    LDT 2005 & Civil
    3D
    *Bill Farley
    04-27-2005 01:22 PM in reply to: *Tim Duzan
    just follow the same setup but instead of F12 use
    cntl-I or one of the other cntl-* keys that are not pre-defined
    than Civil 3D. F12 is now used to toggle on Dynamic, so that takes this option
    out.
    appreciated.
    Tim Duzan
    Jones & Boyd, Inc.
    LDT 2005 &
    Civil 3D
    width=578>
    vAlign=top>
    border=0>
    width=500>
    menu
    buttons pop-up your OSNAP menu (instead of having to hold down
    the SHIFT key and right-click) try this:
    go to the Windows Control Panel, double-click the mouse settings
    Assign the button that you would like to use for OSNAPS as F12 (
    since this funciton key is not used for anything else
    then Toolbars.
    drop a User-Defined Button out of the dialog box. This just made
    a new button and toolbar.
    the button something, like OSNAPS. Look for ^C^C in the Macro
    text field, and type
    Toolbar. If you have the right toolbar it should say OSNAPS
    under Commands. To the right under Press new shortcut key: pick
    the F12 button. Click the Assign button, Close, and try
    it.
    function to your mouse
    buttons.
    in?
    Tim Duzan
    Jones
    & Boyd, Inc.
    LDT 2005 & Civil
    3D
