• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Accepted Solution
    Opening drawing in Civil 3D 2013 and drawing view changes
    395 Views, 7 Replies
    11-28-2012 05:49 AM
    Recently upgraded to Civil 3D 2013 and drawings opened up fine.  Now today any drawing that opens shows the plan view as last saved but then after loading takes the drawing and shifts it into a 3d view similar to a crossection.  Is there a setting somewhere that has been changed?  I noticed after a windows 7 update was preformed.  Thanks.
    dwg ucs opening
    Please use plain text.
    Valued Contributor
    Re: Opening drawing in Civil 3D 2013 and drawing view changes
    11-28-2012 07:45 AM in reply to: srolwes
    I think it is a known bug.
    You can add "plan" to your acaddoc.lsp.  But that isn't always the desired result.  We did add the plan button to the Quick Access Toolbar.
    In my opinion this has been the buggiest release in a long time, yet still no service pack.
    Hope that helps,
    Conan Witzel
    Active Member
    11-29-2012 07:26 AM in reply to: srolwes
    Seems to happen when switching from paper space to model space.
    Product Support
    Matt_Haokip
    11-30-2012 06:29 AM in reply to: srolwes
    Hi Steve,
    I belive the issue you reported have been fixed with the recent release of Civil 3D 2013 SP1. Please download the SP from the following link and let us know the outcome: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20980082&linkID=9240698
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Mangkhothang (Matt) Haokip
    Product Support Specialist
    Autodesk, Inc.
    Active Member
    12-04-2012 05:31 AM in reply to: srolwes
    Service Pack 1 has fixed the issue.  Thanks.
    Active Contributor
    12-08-2012 03:43 PM in reply to: srolwes
    i installed 2013 less than a week ago(i assume it has this service pack), and it is still doing what is described above.  both when entering autocad and when going from a layout to a model tab.  i also noticed it resets ucsfollow to 1.
    super annoying.
    *Expert Elite*
    12-08-2012 04:22 PM in reply to: boyerengineering
    Don't assume anything. If you know you told the installer to also install the Service Pack then it was installed. However, the SP was just released a week ago so there's a high probability it wasn't even available when you installed. Check the About screen to be sure:
    Active Contributor
    12-08-2012 04:28 PM in reply to: Jeff_M
    wow.  i assumed it had been out for a bit.  i dont have it.  thats annoying.  should have waited 3 days to install it.
    thanks.
