• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Re: Offset a surface
    11-19-2012 09:29 AM in reply to: neilyj
    Neil,
    looking at your pretty picture there; isn't a MAPCLEAN going to delete one or the other of the endpoints on the magenta lines?  If so, that's not correct either.  Neither endpoint is right, the intersection of the lines is the point you need.
    Sounds like we need some sort of TRIM & EXTEND command for surfaces, to find that intersection (or FILLET with zero radius).
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Please use plain text.
    neilyj
    11-19-2012 10:25 AM in reply to: Sindarin
    indeed and that pretty picture is only considering a 2D view, its even more complicated in 3D.
    mapclean, snap clustered nodes is about the best approximation at the moment
    neilyj
    (No connection with Autodesk other than using the products in the real world)
    IDSP Premium 2014 (mainly Civil 3D 2014 but also 3ds Max Design)
    Win 7 Pro x64, 256Gb SSD, 300Gb 15,000 rpm HDD
    16Gb Ram Intel Xeon CPU E5-1607 0 @ 3.00GHz (4 CPUs), ~3.0GHz
    NVIDIA Quadro 4000, Dual 27" Monitor, Dell T3600
    neilyj
    11-19-2012 10:27 AM in reply to: Sindarin
    and as Allen said its worse as the offset increases.
    neilyj
    ArchD
    11-19-2012 01:23 PM in reply to: vk_topo
    I just tried vk_topos method and it is pretty fast. But I do believe after creating the new offset surface a step or two should be added.
    Setting it to show points only and extracting them so that MAPCLEAN can be used to consolidate the point clusters down to one point per cluster, and added those consolidated points to a new surface will give it a more accurate offset surface and smaller file.
    I think until Autodesk adds this to Civil 3D, this will be my method of choice.
    Archie Dodge
    Civil 3D 2013
    Windows 7 64-bit
    Xeon W3550 3.07 GHz
    Nvidia Quadro 4000
    12.0 GB RAM
    11-19-2012 02:04 PM in reply to: ArchD
    Archie, as Allen said: "The problem is that the solution would be the intersection of the 3D Faces.... Not the average of the endpoints."
    So I don't see how Mapclean gets you a more accurate surface.  Smaller file, yes.  And probably no less accurate, but not more accurate.
    New Member
    12-11-2012 08:29 AM in reply to: troma
    Guys:
    I read this topic with interest and I have something to share.
    If you have access to ArcGIS and the extensions Spatial Analyst and 3D Analyst, you can basically build a TIN on ArcGIS, convert to raster, and use the raster calculator to get an approximate offset, then convert back to contours. I used this procedure many times to do offset surfaces and tapered offset surfaces. I can post detailed instructions if you guys are interested.
