• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    AllenJessup
    Re: Offset Problem 2013
    07-25-2012 11:36 AM in reply to: engrtech
    Well.... It might alert them to the problem. You can attach a small drawing or ask for a link to upload a larger on, so they'll be able to see your examples. I've had mixed results with SRs, but it's worth a try.
    BTW. I don't have 2013 so I can't look at your examples.
    Allen
    Please use plain text.
    Active Member
    01-30-2013 11:03 AM in reply to: engrtech
    You might try using the Express Tools Offset command.  EXOFFSET
    Jim Haglund
    "It's never too late to have a happy childhood"
    Jim Haglund
    Active Member
    01-30-2013 11:28 AM in reply to: engrtech
    Were the lines you are having trouble with imported from survey data? I usually explode those feature lines, convert them to 2d polylines and flatten them to zero elevation. Then I don't have problems with offsets of curb lines, etc.
    02-11-2013 06:57 AM in reply to: george.skinner
    I was trying to draw new medians in an existing road.  I drew a polyline on top of the survey figure for the edge of pavement, snapping to the end points of the figure(s). I then set the polyline to 0 elevation. Then I offset each side inward by 13.5' for my outside lanes and that told me what the outside edges of my new median would be. The problem was that after I connected the two edges together and made a single polyline that when I'd go to offset it 0.5' inward to create the BOC that I ran into the problems.
    To get the existing edge of pavement, face of curb, and back of curb we use the survey codes to do that automatically so we don't have to draw them. Works great and makes it much faster to get a surface. We never explode a survey figure as that leads to problems later on for us.
    Civil 3D 2013 x64
    Civil 3D 2014 x64
    Windows 7 64-bit
    6GB RAM
