AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Offset Alignments Go Crazy
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a centerline alignment with two offset alignments that reference it (road edge). At the curves throughout the 3+ mile segment I manually added widening to the offset alignments at the curves. I now need to go back and add additional curves to the centerline alignment. I'm trying to do this by adding additional PI's to create a new tangent where I want the curve, then deleting this tangent and adding in the new curve. When I delete the new tangent sub entity my offset alignments get cut off at end of the alignment (where I deleted the tangent). This causes all of the widenings I had created to be bunched up at the section of remaining CL Alignment. When I build a new curve through the deleted portion and re-establish the alignment to its full original length the offset widenings do not re-associate to their original stationing (they remain bunched up at the first few hundred feet.
Is there a way to add curves to the alignment without losing the stationing for my curve widening on the offset alignments? I attached a screenshot of what happens to my offsets (red) when I delete a section of the CL alignment, the widening remains all bunched up when I reconnect the original alignment.
Re: Offset Alignments Go Crazy
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Don't delete the tangent, use Free Curve Fillet and select the two entities you want to fillet then enter the radius.
Windows 7 x 64
AMD FirePro V7900
12 GB Ram
Xeon E5620 @ 2.40 GHz
Civil 3D 2010
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Adam, figured this out just a few minutes ago. Overthinkg it as usual!
