• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Mentor
    Odd Bearing listing using CGLIST
    230 Views, 16 Replies
    09-10-2012 05:51 AM
    I routinely create blocks of deed descriptions, subdivisions and other plats to create mosiacs of properties that I will later use for the calculation of additional field points on a survey being preformed. However when I create a block, and list a line that has been rotated it still reports that the line is due south or whatever bearing it was originally drawn at.
    Is this supposed to work this way? Is there a setting that I'm missing somewhere?
    If this is the way it works - it is totally wrong in my opinion, and is a serious deficiency with respect to the surveying.
    TIA
    C3D12
    Please use plain text.
    AllenJessup
    Re: Odd Bearing listing using CGLIST
    09-10-2012 06:56 AM in reply to: rl_jackson
    I've not experienced this since I don't list bearings in rotated blocks. But I do have a theory.
    A block is a single definition in the drawing shown multiple times. So I think what's happening is that CGList is reporting the bearing from the original definition.
    I do have a workaround since I work in a similar manor. Instead of using Blocks use Groups. While this will double or triple, in my case, the amount of linework in the drawing. Lines don't increase a file's size that much. This still allows you to move the deed plots as a single unit but you can still affect the lines individually if you want.
    I triple the size because I have one instance of the lines in their original bearing systems, one where I have created a mosaic in the system that seems most common the them and one where I've rotated them after a field analysis.
    HTH
    Allen
    Valued Mentor
    IanMcClain
    09-10-2012 07:40 AM in reply to: rl_jackson
    I agree. It would be best if the command gave the original data of the block and the scaled/rotated data. Or another command that gave the real data would be sufficient. Also, if you cglist an arc in a block, you don't get the arc information.
    -Ian McClain
    (running C3D 2012 sp3, Win7 64bit)
    Valued Mentor
    09-12-2012 08:34 AM in reply to: AllenJessup
    Thanks Allen, That's a pretty good analogy of what is going on with regards to CGLIST - Not sure if I like it a whole lot. I tried your method with the group, and that command seem to have changed quite a bit from LDD, I see to remember a dialog box for that command, but I dont get that in C3D12, and I know the settings are correct. This makes it a little difficult to use, as sometimes once I get the final position set, I what to explode/degroup the object, and I dont see that feature. ? Rick
    AllenJessup
    09-12-2012 08:50 AM in reply to: rl_jackson
    To get options for the Group command enter -GROUP (note the hyphen). That will give you the option to explode the group. I agree. Not having the dialog box is something you have to get used to.
    Allen
    AllenJessup
    09-12-2012 08:53 AM in reply to: rl_jackson
    BTW. Remember that if you set the Pickstyle to 0, you will be able to select the individual members of a group.
    Allen
    AllenJessup
    09-12-2012 08:57 AM in reply to: rl_jackson
    I just found out you can get the dialog box by using the CLASSICGROUP command.
    Allen
    Valued Mentor
    09-12-2012 08:59 AM in reply to: AllenJessup
    Ah the hyphen never came up in the command list, since I started it with G, thanks for the help, I will look into the pickstyle variable as well. ? Rick
    Valued Mentor
    09-12-2012 09:11 AM in reply to: AllenJessup
    Looks like its time to do an alias edit ? Rick
    AllenJessup
    09-12-2012 10:23 AM in reply to: rl_jackson
    Or you could get fancy and use the Undefined and Redefine lisp commands in your acaddoc.lsp. See example on page 86 and 87 in this  [Link] .
    Allen
