• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    *Expert Elite*
    AllenJessup
    Note text gone.
    211 Views, 5 Replies
    01-30-2012 10:21 AM
    I had a problem, [Points no longer Drag ], that required me to insert a drawing in to a fresh drawing created from a Template. After I did that all my Note Labels reverted to saying just NOTE. I thought it might be a style problem, I was using a slightly modified General Note style, so I overwrote it from a backup of the original drawing. The notes didn't change. I tried copying a note from the backup and pasting it in to the new drawing. But it reverted to NOTE again. I finally opened each note in the backup and pasted the contents to each note in the new drawing.
    Does anyone know why that might have happened and how to avoid it in the future?
    Allen
    Civil 3D 2011, Version 2, Raster Design 2011
    Windows 7 Pro, 64 bit
    Dell Precision T7400, Xenon X5460, 3.2 GHz, 4 GB Ram
    NVIDIA Quadro FX 4600, 768MB
    Please use plain text.
    *Expert Elite*
    BrianHailey
    Re: Note text gone.
    01-30-2012 01:07 PM in reply to: AllenJessup
    It's reasons like this that I don't recommend inserting one C3D drawing into another, things just seem to get broken. I'm sorry I don't have a better answer for you...
    *Expert Elite*
    AllenJessup
    Re: Note text gone.
    01-30-2012 01:55 PM in reply to: BrianHailey
    I don't disagree. But the was the "Fix" for the previous problem.
    The cure may be worse than the disease. I now have some other weird problems. In some cases the Linetype scale for "some" linetypes are messed up. I've checked the LTscale for the drawing and the individual entities and checked 3 or 4 times that the drawing scale is set correctly. But I have to set the LTscale for some lines to 0.1 in the new drawing to get them to display the same as in the old drawing.
    The other weird thing is it's basic Autocad entities I'm having the most trouble with. The Civil 3D objects seem to have com through OK. The exception was the display of the contours for the existing surface. But it turned out that if I set the LTscale in the Surface Style to 0.1 they displayed the way I want them.
    I admit that some of the trouble with this drawing may come from not getting it set up right from the beginning. It was supposed to be for the redesign of a portion of a parking lot that's part of a bigger job. Over time I've added alignments, profiles, corridors, etc. as more check and redesign is needed. Of course I don't have time to break it up as it should be. I have to keep ahead of the excavators. Why couldn't we have 3' of snow in the Northeast!!
    Allen
    *Expert Elite*
    johnm
    Re: Note text gone.
    01-31-2012 09:24 AM in reply to: AllenJessup
    If you had any label overrides assigned to other labels (srf, stc, pipes, etc) you lost them too. This will also happen if you swap a label style. Annotative text styles have been a much better solution for us with notes and call-out labels.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    *Expert Elite*
    AllenJessup
    Re: Note text gone.
    01-31-2012 09:31 AM in reply to: johnm
    I've needed to reestablish a few overrides. But that's easy and there weren't many. The weirdest is the LTscale. Still haven't figured that out. Also. Every Point Group was duplicated 5 times. Took a while to delete all of them.
    Luckily this drawing will never be published as a plan set!!
    Allen
    Distinguished Contributor
    Re: Note text gone.
    04-30-2012 11:11 AM in reply to: AllenJessup
    We just switched to Civil 3D (2012) and this is a major problem for us.  We are always having to copy with basepoint and paste into another drawing or insert one drawing into another.  The fact that notes reset to the default text of the note style makes them pretty much useless.  I can understand other overrides being reset to whatever is defined in the drawing, but if you edit label text then they should keep that text with them.  Does anyone know if this behaviour has changed in 2013?
