• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Member
    MurraySimon8160
    Accepted Solution
    North Arrow Alignment with Plan Production
    1277 Views, 4 Replies
    01-31-2011 05:31 AM
    I'm using the Plan Production tools to create alignment drawings and when adding the north arrow during the process i get a error at the end stating @unable to align north arrow?
    North arrow is a block and tried with basepoint and alignment parameters, unless i have missed something in the block creatation?
    How do i create a north arrow block that will align with the layouts in plan production?
    Please use plain text.
    *Expert Elite*
    Joe-Bouza
    Re: North Arrow Alignment with Plan Production
    01-31-2011 06:15 AM in reply to: MurraySimon8160
    Only a guess: Does your block definition point straight up? Perhaps if you edit an existing block and replace the entities wiith yours?
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    Member
    MurraySimon8160
    01-31-2011 06:48 AM in reply to: MurraySimon8160
    Yes the north arrow in the block does point straight or the top of the screen. Is there something that needs to be set in the block parameters?
    Can someone send me a Nth Block that works?
    *Expert Elite*
    Joe-Bouza
    01-31-2011 05:20 PM in reply to: MurraySimon8160
    I don't think it needs to be a dyno block, I use the old softdesk north arrow that been around for eons, and it works fine. Think about it, why would you want t o grip rotate you NA after PP did it for you :smileywink:
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    Valued Mentor
    LisaPohlmeyer
    02-01-2011 08:54 AM in reply to: MurraySimon8160
    Is your north arrow placed over the Plan viewport in the template you're using?
    Lisa
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
