• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Accepted Solution
    Node osnap not recognizing certain point marker styles
    507 Views, 7 Replies
    10-31-2012 12:32 PM
    Is there a reason why the "node" osnap won't recognoze certain point markers?  I have recently begun using named plot styles and I have been revising some of our markers to reflect this.  I have noticed that some of the point markers (it seems like markers that use a circle as part of the marker) won't show the node marker no matter how I hover around it.  Others seem to be normal.   Thanks for any help.
    Please use plain text.
    *Expert Elite*
    AllenJessup
    Re: Node osnap not recognizing certain point marker styles
    10-31-2012 01:18 PM in reply to: Jason__M
    Which release of Civil 3D are you using? I've been told that 2013 will node snap to all markers and previous version don't.
    Allen
    Civil 3D 2012
    Valued Mentor
    10-31-2012 02:57 PM in reply to: Jason__M
    When this happens, insert the block used in the points style, go into block editor by selecting the block and right-clicking. Then go through and recreate things a little, I have had it happen on my point styles as well.
    *Expert Elite*
    Neilw
    11-01-2012 01:19 AM in reply to: Jason__M
    Welcome to the world of custom ARX objects. I wonder how much time has been wasted by users trying to figure out how to snap to geometry of C3D objects.
    Neil Wilson (a.k.a. neilw)
    Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
    WIN 7 64 PRO
    HP Pavillion h8xt, i7 2600, 12 GB
    RADEON 6450, 1 GB
    http://www.sec-landmgt.com
    *Expert Elite*
    AllenJessup
    11-01-2012 05:01 AM in reply to: Neilw
    A lot. I still want to know why I can get an endpoint or nearest osnap on a profile but not a perpendicular or intersection.
    Allen
    Active Member
    11-01-2012 05:05 AM in reply to: Neilw
    Forgive my ignorance.  When you say time wasted is it wasted because people don't know the right way to fix it, or is it wasted because people spend time trying to fix something that might no be fixable?
    I am currently using 12.  I tried the markers out in 13 and Allen seems to be right.  They worked like a champ there.  I guess it's time to reluctantly move up.
    Thank you all.
    *Expert Elite*
    AllenJessup
    11-01-2012 05:17 AM in reply to: Jason__M
    That might not be reason enough. At least not till the first SP, There's always the 'PN or 'PO transparent command to "snap" to a point.
    Allen
    Active Member
    11-01-2012 05:28 AM in reply to: AllenJessup
    I didn't think about 'PO.  That's much better than moving up.  Thanks again!
