• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Distinguished Contributor
    ACADuser
    Need help with subassembly selection (c3d 2012)
    217 Views, 8 Replies
    12-04-2012 01:00 PM
    I have a simple road widening project and am having a difficult time trying to figure out which subassemblies to use. The design calls for widening the road on one side.  The widening vairies in width and is a constant 2% slope (away from the cl) across the new section, a vertical curb and then daylight to existing ground.  I have a main allignment defined at the cl of the existing road from which construction staking will be used, an alignment representing a sawcut at the inside edge of the widened section, an aligment at the outside edge of the widened section.  I have tried the OverlayWidenWithSuper1 without success, and have tried reading through the help but am finding it very confusing as there is no table of contents.
    Can someone please help point me in the right direction?
    ACADuser
    Dell Precision T5500 Workstation
    Windows XP Professional SP3
    Dual Quad Core Intel Xeon Processors E5540 2.53GHz,8M L3,5.8GT/s,turbo
    4GB, DDR3 Memory, 1066MHz, ECC (4 DIMMS)
    1.5GB NVIDIA Quadro FX 4800, DUAL MON, 2DP & 1DVI
    160GB, 3.0Gb/s, 16MB Data Burst Cache,SATA2,10K RPM Hard Drive
    16XDVD AND 16XDVD+/-RW
    Please use plain text.
    Joe-Bouza
    Re: Need help with subassembly selection (c3d 2012)
    12-04-2012 01:26 PM in reply to: ACADuser
    If you are not matching the existing road cross fall then you can use an offset assembly with outside super set to 2%, curb a daylight attched.
    attach the offset the the sawcut and the eop the widen line
    Thank you
    Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
    HP Z210 Workstation
    Intel Xeon CPU E31240 @ 3.30 Hz
    12 GB Ram
    Note: Its all Resistentialism, so keep calm and carry on
    64 Bit Win7 OS
    sboon
    12-04-2012 04:56 PM in reply to: Joe-Bouza
    Joe's method will work but there is a potential pitfall to consider.  When you use an offset assembly the software treats that alignment and profile as a semi-independent baseline in the corridor.  This means that any corridor sections built from the offset baseline will be perpendicular to that alignment, not the road centerline.  Some people find that this is an issue if the sawcut line has bends and tapers in it.
    Another method which can work is to add a generic LinkOffsetOnSurface from the centerline and target that to your sawcut line.  You can hide this link so that it's invisible in your sections later.  Attach the lane sub to that with a width target.
    ACADuser
    12-05-2012 01:14 PM in reply to: sboon
    Steve,
    A few questions if you don't mind.
    The offset alignment is not parallel to the centerline and also has tapers/bends.  Given this and what you are saying I assume the cross slope of the widened section will not be 2% when measured perpendicular to the centerline.  Is this correct?
    How is it that you "hide" the link in the sections?
    ACADuser
    ACADuser
    12-05-2012 01:16 PM in reply to: Joe-Bouza
    Joe,
    This works just as expected.  Although I am leaning towards using Steve's method due to the offset alignment not being perpendicular to the centerline.
    Any idea why the OverlayWidenWithSuper1 does not work in this situation?  Seems like an appropriate assembly name for the job.
    ACADuser
    Joe-Bouza
    12-05-2012 01:24 PM in reply to: ACADuser
    Thats great!
    One thing to consider: when the paving machine is following the sawcut line is the screed perpendicular to the centerline of the sawcut line?
    Thank you
    HP Z210 Workstation
    12 GB Ram
    64 Bit Win7 OS
    ACADuser
    12-05-2012 01:56 PM in reply to: Joe-Bouza
    Yeah, for sure.  But that just makes for a more complicated design.  No?  I could get away with using your method but when it comes to labels being dynamic, it's much easier to produce consistent labels using the other method.  That translates into a much easier to check/read set of plans.
    ACADuser
    sboon
    12-05-2012 02:08 PM in reply to: ACADuser
    Yes - with an offset assembly and baseline everything is relative to that baseline, so your design sections would be 2% measured perpendicular to the sawcut line at that location.
    Most of the generic link subassemblies have an option to "hide link" in the properties dialog.  Once that option is turned on the link disappears from the assembly and all corridors where it's used.
    OverlayWidenWithSuper would likely have been my default solution for this scenario.  You didn't elaborate on why you're having trouble with it, but I'm guessing that you're having difficulty with the targets required to make it work.  Try the link below to go directly to the help page for this sub.
    http://docs.autodesk.com/CIV3D/2012/ENU/filesCSH/GUID-135FE114-5CAF-42A6-8CCD-C29225E5C29-94.htm
    ACADuser
    12-06-2012 06:53 AM in reply to: sboon
    The issue I was having with the OverlayWidenWithSuper1 was not targeting, but rather the slope of the section was level rather than -2%.  The solution you provided works great, Thanks :smileyhappy:.
    ACADuser
