• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Valued Contributor
    Navisworks 2013 fatal error
    602 Views, 3 Replies
    04-21-2012 07:06 AM
    Hello all,
    I can't append C3D 2013 files on Navisworks. Firstly I was able to append the file but I couldn't "see" C3D objects then I found here that I should install  C3D 2013 Object Enabler on Navisworks... now, after this installation (that should be mandatory when install Navis on Infraestructure modeller), the window freezes on "loading" and, sometimes, I get the fatal error msg: Unable to load file 'AcTcUiRes.dll'.
    I already reisnstalled Navis and Object Enabler with no results... Do you guys would know what should be done?
    Thanks a lot,
    Diego Álvares
    Civil Engineer - www.trentoengenharia.com.br
    Autocad Civil 3D 2013 - Infrastructure Design Suite
    Windows 7 64 i7 860 @2.80GHz 8GB Ram Quadro 2000D
    Please use plain text.
    Active Contributor
    Re: Navisworks 2013 fatal error
    04-25-2012 05:13 PM in reply to: diegoal
    We were able to open our files until we loaded the Object Enabler after that DLL error one right after anther. Looks like a BUG in the patch.
    KW
    Valued Contributor
    04-26-2012 09:56 AM in reply to: keithw
    Hello KW,
    Yes it seems a BUG... I've writed to Autodesk and they sent me some instructions:
    "Dear Diego,
    I was able to reproduce the issue after installing Civil 3D 2013, the Civil object enabler, and Navisworks 2013 on a test machine.
    I found another workaround in that if you turn off AutoCAD and Civil 3D properties in DWG reader, the error no longer occurs when opening your DWG.
    Please try the following :
    1. Delete the NWC file that was created upon opening the DWG in Navisworks 2013.
    2. Open Navisworks 2013
    3. Click Application Button > Options and expand File Readers > DWG
    4. Click the Advance button in the bottom of the list of options
    5. Unmark the AutoCAD and Civil3D boxes
    NOTE:  Leaving AutoCAD marked will result in the 4 error windows and a freeze.  Unmarking and leaving Civil3D results in the application hanging at 2% while loading the file in my test.
    6. Click OK and open the Civil 3D DWG file.
    This first try didn't worked for me...
    The side effect is that the AutoCAD and Civil 3D properties are then not able to covert and be used in Navisworks.   Therefore the best workaround would be to export directly from Civil 3D using the NWCOUT command.  If you installed Civil 3D after Navisworks, then this command may not be recognized.  If that is the case:
    1. Open Control Panel > Programs
    2. Open Autodesk Navisworks 2013 64-bit Export plug-ins
    3. Click Add/Remove features
    4. Mark the checkbox for AutoCAD 2013 and click update to install.
    After loading the DWG in Civil 3D 2013, enter the command NWCOUT. This should allow you to save to an NWC file.  This also has the benefits in that it doesn’t require all users to have the enabler installed or their AutoCAD options set up the same way to view the model the way you intend.  By entering NWOPT in AutoCAD you can set the options and they will set in that NWC.
    If you are receiving these DWG files from another outside source and don’t have Civil 3D 2013 yourself, that other user can download and install the standalone exporters from the following page without having to install or license Navisworks Manage or Simulate and provide you NWC files:
    http://usa.autodesk.com/adsk/servlet/pc/item?id=13947462&siteID=123112
    Please give this a try and let me know if this works on your end.
    I’ve documented your case with our development team so that they are aware that more users are experiencing this issue."
    NWCOUT worked very well so I forgot to try to append Civil 3D DWGs...
    KW, I hope it helps you too.
    Best regards,
    Diego Álvares
    New Member
    12-18-2012 12:28 AM in reply to: diegoal
    I find it very frustrating that with all the development that is taking place we are unable to open native 2013 Civil 3D files in Navisworks. Not only have I had trouble with pipework, but corridors have to be run through a corridor solids app first then exported. A real time waster!  Yes there are work arounds but this affects the workflow of the project and carrys the inherent danger of incorrect or out of date files being used.
    AUTODESK can we PLEASE resolve this.
