AutoCAD Civil 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Naming convention s for C3D objects
- Highlight
- Email to a Friend
I am working on standard naming conventions for Civil 3D objects. Surfaces, alignments, profiles, etc. This is so everyone in the company will name their C3D objects with names that make sense to everyone. So far I have the surfaces done, but am unsure of where to go with the other types of objects. If anyone has a standard naming conventions that works well, I'd like to hear it. Here is what I have for surfaces:
1) Surfaces
a) EG - Existing grades surface
EG is used to identify any surface created from any type of existing data.
- EG Finalized existing grade surface. This surface may be comprised of Aerial topo, Lidar contours, pasted survey surfaces, etc.
- EG-Aerial Surface created from Aerial topo
- EG-Lidar Surface created from Lidar data.
b) FG - Finished grade surface
FG is used to identify any final grade surfaces
- FG Finalized finished grade surface. This surface may be comprised of various pasted transitional grade surfaces or may simply be one single surface created using the grading tools.
- FG-Lot-Name Finished grade for a specific parcel. i.e. FG-Lot-1
- FG-Septic Finished grade for a septic system.
- FG-Basin-Name Finished grade for a basin. i.e. FG-Basin-A
- FG-Road-Name Finished grade for a road. i.e. FG-Road-Brodhead
c) SG - Survey grade surface
SG is used to identify any surface created from survey data.
- SG-Road-Name A surface created from surveyed points for a road. i.e. SG-Road-Brodhead
- SG-Stream-Name A surface created from surveyed points for a stream. i.e. SG-Stream-1
- SG-River-Name A surface created from surveyed points for a river. i.e. SG-River-Lehigh
- SG-Wetland-Name A surface created from surveyed points for a wetland. i.e. SG-Wetland-1
- SG-Topo A surface created from surveyed points for any miscellaneous ground area.
d) TG - Transitional grade surface
TG is used to identify any surface created to transition between other surfaces. These surfaces are only used to create topo for a feature and then the surface is added to an FG surface at a later point.
- TG-Road-Name A surface generated for a road or access road. i.e. TG-Road-Brodhead
- TG-Trap-Name A surface generated for a trap site. i.e. TG-Trap-Chase
- TG-Basin-Name A surface generated for a basin. i.e. TG-Basin-A
e) VOL – Volume surface
VOL is used to identify any surface created as a volume surface to calculate the volume between two other surfaces and/or to display the cut/fill between the two surfaces. To make it easy to tell which surfaces the volume surface is doing the calculations for be sure to include the surface names in the name of the volume surface. See below for an example.
- VOL-EG to FG A surface created to calculate the volume between the EG surface and the FG surface.
Re: Naming convention s for C3D objects
- Highlight
- Email to a Friend
Template looks good. Keep going
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
- Highlight
- Email to a Friend
Agreed... good job ![]()
"Very funny, Scotty. Now beam down my clothes."
- Highlight
- Email to a Friend
For a reconstruction job we will typically have at least two alignments for a street:
CL OLD STREET the actual control line, stationing etc.
XCROWN OLD STREET alignment along the existing crown. This will be profiled and superimposed so we get existing crown profile on control line stations
We may also superimpose profiles from the matchpoint, so I have used the names
XBS EAST
XBS WEST
for the back of sidewalk alignment. Typically I will give the same name to the profile too.
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
__________________________________________________________
Credit where credit is due! Give kudos or accept as solution whenever you can.
- Highlight
- Email to a Friend
To my thinking, simply using EG and FG for surface object may confuse your folks because EG and FG could equally mean existing and finished profile. I'd suggest something like
EG-SURF and FG-SURF
EG-SURF-AERIAL
EG-SURF-LiDAR
EG-PROF and FG-PROF
- Highlight
- Email to a Friend
Just to reply we use a similar practice and no one confuses an FG surface with an FG profile lol... not even sure how one could.
- Highlight
- Email to a Friend
I agree. And I follow the EG FG convention from all the Autodesk tutorials. I like short names & long descriptions
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
