• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Named UCS Civil 3d 2013
    344 Views, 7 Replies
    06-13-2012 08:26 AM
    I am curious if any one else is having issues with "named UCS" in Civil 3d 2013.
    Often when we open a drawing where we have a named UCS, the view will switch to some sort of 3d view.  This will also occur when switching from paper space to model space.
    While the drawing is opening, you can see the view as it was when the drawing was saved and at the end of the load process it will flip.
    I had thought it might be something in our acaddoc.lsp but it also happens when switching from paper space.
    Conan Witzel
    Civil 3d 2013 64 Bit
    Windows 7 64 Bit
    Please use plain text.
    *Expert Elite*
    AllenJessup
    Re: Named UCS Civil 3d 2013
    06-13-2012 08:34 AM in reply to: cwitzel
    Some may disagree with me. But I think it's a bad idea to us UCSs in Civil 3D. As to you problem, since I don't use them I haven't any experience. The only thing I might suggest is to set the drawing to the WCS before saving.
    Allen
    06-13-2012 08:39 AM in reply to: AllenJessup
    Whenever we are doing annotation we do it ortho to a property line.  Unless I am missing something the only way to do this is with a UCS.
    We do keep civil 3d drawings, such as our grading drawing, in WCS as some features don't work in the Named UCS. However anyplace we have annotation such as Dimensional Control has a UCS.
    We have not had issues prior to 2013.
    Conan
    Valued Mentor
    LisaPohlmeyer
    06-13-2012 09:30 AM in reply to: cwitzel
    Conan,
    We set our label styles to be roatated with the view instead of the object.  Look on the General Tab of the label style.
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    *Expert Elite*
    AllenJessup
    06-13-2012 09:54 AM in reply to: cwitzel
    I've never had to set a UCS yet. Dview has always worked for us. Granted we don't do too much subdivision work.
    Allen
    06-13-2012 09:54 AM in reply to: LisaPohlmeyer
    Lisa,
    Nice to hear from you!
    We do that for all of our Civil 3d annotation, but we still have a lot of callouts, dimensions etc that are not Civil 3d based.  In addition whenever we are doing layouts, we like to be ortho to one or more of the property lines.
    It isn't changing the UCS, just the initial view.ucs
    It has always worked in the past.
    Conan Witzel
    Active Contributor
    11-02-2012 11:32 AM in reply to: cwitzel
    Hi:
    Has anyone found a solution for this? Everything seemed fine in Civil 3D prior to 2013, but now my views get all wonky when switching from paper space to model space when a UCS other than WCS is being used in model space.
    Valued Contributor
    11-04-2012 06:40 PM in reply to: cwitzel
    Sadly I hope we are awaiting SP1. AutoCad and Map are both out so it should be coming soon and I certainly hope this is part of the patch.
    Conan Witzel
