• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    fayoud
    .NET Framework Runtime 4.0 Language PackFailed Installation aborted, Result=1603
    468 Views, 3 Replies
    10-21-2012 04:14 PM
    i need to help, i have problem with framework installation with civil 3d 2013 x64
    this is my log file
    Oudjhih Fayçal
    Please use plain text.
    *Expert Elite*
    Re: .NET Framework Runtime 4.0 Language PackFailed Installation aborted, Result=
    10-21-2012 05:32 PM in reply to: fayoud
    have you tried to setup this manually before starting the Civil3D-setup (and have you had full admin-rights, all antivirus- and/or defending software disabled).
    What OS do you have?
    - alfred -
    Alfred NESWADBA
    Ingenieur Studio HOLLAUS ... www.hollaus.at
    Active Member
    fayoud
    10-22-2012 01:08 AM in reply to: alfred.neswadba
    i use windows 8 x64 Pro activated on HP laptop, without any antivirus
    Oudjhih Fayçal
    *Expert Elite*
    10-22-2012 02:30 AM in reply to: fayoud
    >> i use windows 8
    AutoCAD 2013 (and so also Civil 3D 2013) is not built for Win8, supported OS are Win7 and WinXP (>>>click<<<)
    And as Win8 has limitations in installing old Frameworks you have to modify the installation-config-file (but make sure firsts if you are allowed to modify that, I'm not sure if license-regulations by default disallows modification of binaries- or setup-files. Ask your dealer or Autodesk therefor). Anyway I would not suggest to run on Win8 for productive projects.
    You may look to >>>this thread<<<, that shows for Mech2012 what to do to get it running.
    - alfred -
    Alfred NESWADBA
