• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Multiple alignment grades on cross sections
    159 Views, 2 Replies
    07-09-2012 11:59 AM
    using Civil 3d version 2012
    Want to add existing and proposed profile grades to cross sections for the eastbound and westbound lanes.  I have an alignment established for each
    thanks
    Please use plain text.
    *Expert Elite*
    Re: Multiple alignment grades on cross sections
    07-09-2012 07:05 PM in reply to: sniff26
    For proposed:
    I would place a markedpoint subassembly in the middle of each lane in your assembly. Name is something special and then adjust your code set style accordingly so that the propsed grades get labelled.
    For existing:
    Plave a link vertical at the above generic link and target your EG surface. Place another markedpoint named something else at the end of this link. Again, modify your code set style.
    This is off the top of my head, there may be a better way. But this method will work.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
    07-18-2012 12:12 PM in reply to: mathewk
    There is no way to establish a band that references the exisitng and proposed surfaces at the geometry that I have already established?  This seems like a pretty common occurance, lots of divided highways out there
