• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Member
    Multiline text being converted into separate multiline texts
    135 Views, 3 Replies
    01-09-2013 02:09 PM
    I've recently noticed that my multiline text boxes in old drawings have been splitting themselves into multiple multiline text boxes.  They aren't exploding into single line text because it won't let me use the convert command to turn them into multiline because they are already multiline.
    I know the dimassoc command can be set to a certain value to cause all dimensions to explode but is there some kind of command that could have change itself and is causing this problem?
    Hopefully that explanation made sense...
    Thanks for the help!
    Please use plain text.
    *Pro
    Re: Multiline text being converted into separate multiline texts
    01-10-2013 11:11 AM in reply to: fordtruckman
    mtext boxes do not just split them selves.   They don't explode into multiple mtext boxes either.   They explode to dtext.
    I've never seen what you're seeing.   I can just tell you that is not typical behavior.
    Dan
    Civil 3D 2013
    Win 7 Pro x64
    Intel Xeon 2.0GHz
    6Gb Ram
    ATI Firepro 4800
    Dell T5500
    www.preinnewhof.com
    Active Member
    01-14-2013 06:16 AM in reply to: dgordon
    Ok so even if they explode themselves to single line text blocks then there still isn't a command that controls that?
    I was hoping it was some kind of setting that auto-exploded multiline text.  Don't know why you'd ever want that but, was hoping that existed so I could fix my issue.
    Valued Mentor
    01-14-2013 06:39 AM in reply to: fordtruckman
    I got this lisp routine on this discussion board some time ago, it converts multiple dtext objects to single mtext objects.
    Hope that helps
    Rick
