AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Multileade r with block plotting issues
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Attached is a drawing containing various multileaders we use for callouts on our plans. The most used one is the circle callout which uses a _TagCircle block. If we create a new circle callout, the multileader plots fine. If we copy the multileader to label a similar object, the resulting multileader plots the same color as the layer, as if it had a "none" plot style. The block itself (i.e. not as part of a multileader) plots correctly, regardless if it is copied. The other callouts (triangle, square, etc.) function correctly whether copied or not. I cannot figure out what is difference is between the circle and the other callout blocks. Our work-around is to put the blocks on a layer that is white, but that doesn't follow our company standards which calls for text layers to be typically yellow. Also attached is our plot style, renamed to add a txt extension so it could be attached. Any ideas as to what I am missing? Thanks.
