AutoCAD Civil 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Multileade r block colors
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have a road construction ahead sign where I have hatched the background orange (color 30) as a mask since I am using an airphoto for the drawing background. The block is fine until I try to use it in a multileader, then the hatch color switches to block and I can't read the text. The block was created on the same layer as it is inserted. How do I get the orange hatch to show as orange in the multileader block? See the attached screen shot.
LT, C3D 2005 - 2014
XP, Vista, 7
Re: Multileade r block colors
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just quickly repeated what I think you did, and it works fine here in an MLEADER.
The block is on the right, and the MLEADER on the left.
R.K. McSwain
CADpanacea.com | twitter | Cadalyst Tips
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The problem has something to with going to a layout. The multileader looks fine in the model tab, but in a layout, both in paperspace and model space the hatch changes color to solid black. It also has to do with the plot styles because when I turn off display plot styles, the colors are fine on the screen. I tried selecting one that I am sure plots color, the none, and the default acad.ctb and all of them show up black on the screen. I tried printing it to PDF, and it prints in color, so I have a bit of a workaround, but I would like to see what I am working with. Any thoughts?
LT, C3D 2005 - 2014
XP, Vista, 7
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What if you use a truecolor instead of ACI color 30?
It sounds like your STB/CTB is mapping color 30 to a black "pen".
Truecolors are not affected by plot styles.
R.K. McSwain
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
True colors didn't work. It is an issue with display, and the multileader uses the block without any modifications, so I don't understand why the block is fine but the multileader isn't. If it were a problem with the CTB files, I would expect the problem to affect the block and the multileaders, and the plots. The problem is only with multileaders in a layout tab on the screen.
I guess I have found a bug. Thanks for your help.\
Happy New Year!
LT, C3D 2005 - 2014
XP, Vista, 7
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Have you tried editing the block and explicitly sending the hatch to the back? Making the block dynamic with the leader in it may also avert the display issue?
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
