• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    Active Contributor
    eyescast
    Multi-viewport - text is out of scale.
    150 Views, 5 Replies
    02-04-2013 10:54 AM
    Hi again,
    In paperspace the text are so out of scale and it only shows a specific area of the model view.
    the other viewports will have a realistic and 2d wireframe.
    Please suggest what to do next. I spent the part of the superbowl sunday trying to figure this out.
    thanks again.
    eyescast
    Please use plain text.
    *Expert Elite*
    johnm
    Re: Multi-viewport - text is out of scale.
    02-04-2013 11:44 AM in reply to: eyescast
    Did you regenerate the display after zooming in the viewport? If not activate the viewport by double clicking on it. Type RE into the command line and hit enter.
    John Mayo, PE
    C3D 2012, RD 2012
    Win 7 64, Core i7,
    6 GB RAM, Quadro FX 1700
    Valued Mentor
    Valued Mentor
    sjg
    02-04-2013 11:51 AM in reply to: eyescast
    Looks like the viewport is zoomed to extents, zoom into to the area you would like to show in that viewport and regenall, text should resize. All civil3d labels are based on a scale factor of the annotation scale. Your viewport it is at zoom extents, so the labels are being scaled to that annotation scale.
    Steve Goessling
    Land Consultants
    Civil3D 2012 (Service Pack 2.1)
    Windows 7, 64 bit
    Intel i7 2600 @ 3.40Ghz
    16 GB RAM
    Nvidia Quadro 600
    *Expert Elite*
    02-04-2013 12:08 PM in reply to: eyescast
    If a regen doesn't fix it check the units in the page setup.  These need to match your paperspace units: typically inches or mm (I trust you know whether it should be inches or mm!)
    __________________________________________________________
    Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
    Credit where credit is due! Give kudos or accept as solution whenever you can.
    Valued Contributor
    johngordon6189
    02-13-2013 01:12 PM in reply to: eyescast
    did you toggle these buttons next to the annotation scale?
    *Expert Elite*
    02-13-2013 05:20 PM in reply to: eyescast
    Those buttons do nothing for Civil 3D labels.
    Matt Kolberg
    Cansel - Autodesk Division
    http://www.cansel.ca/
