AutoCAD Civil 3D
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Mtext Bullets and Lists
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
88 Views, 1 Replies
12-17-2012 07:51 AM
I have a large body of text that is numbered and i need to break it into two separate mtext blocks. is there any way to keep the numbering continuous between the two blocks? every time i delete the redundant text in the second mtext block it starts my numbering over.
any thoughts?
Re: Mtext Bullets and Lists
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
12-17-2012 08:17 AM in reply to:
CADDuser5678
Do you really need to break it up or can you use columns?
If you do need to break it, type the first number manually. If your numbers are the default ones, you can type it like "9. "
That is whatever number, then a period, then tab. You then may need to go to the end of the line, delete the return code and put it in again to renumber the next line to match.
__________________________________________________________
Win 7 Pro, 32 bit; Intel Core i5 @ 2.80GHz; 4GB RAM—Civil 3D 2008 & 2011
Credit where credit is due! Give kudos or accept as solution whenever you can.
