• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Civil 3D
    JamaL9722060
    Moving profile or alignment,
    281 Views, 13 Replies
    10-18-2012 05:15 AM
    I’m not sure why moving profile introduces a problem! Some data is missed!
    What might be the reason?
    Thank you
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    Valued Mentor
    LisaPohlmeyer
    Re: Moving profile or alignment,
    10-18-2012 06:50 AM in reply to: JamaL9722060
    Using the Move command isn't our preferred method of editing an alignment and/or profile. We use the grip edit tools of both those objects.  Perhaps going through the tutorials on editing alignments and editing profiles would help you.  There's also some good reference material out there, AutoCAD Civil 3D 2013 Essentials and Mastering AutoCAD Civil 3D 2013 are two that we use.
    Lisa Pohlmeyer
    Williamson Co. Dept. of Infrastructure
    Intel i7 3.33Ghz, 16Gb RAM
    Nvidia Quadro 2000D
    C3D 2012 SP3, C3D 2014
    Win 7-64
    Please mark this as the solution if it resolves your issue.
    *Expert Elite*
    AllenJessup
    10-18-2012 07:03 AM in reply to: JamaL9722060
    I just moved a couple of profile views in 2012. I didn't have any problem. Does the design profile still exist in the Prospector?
    Allen
    *Expert Elite*
    AllenJessup
    10-18-2012 07:04 AM in reply to: JamaL9722060
    Are you selecting the Design Profile or the Profile View when you do the Move?
    Valued Mentor
    LisaPohlmeyer
    10-18-2012 07:06 AM in reply to: AllenJessup
    I didn't realize it was the profile view he was moving, I thought it was the alignment or profile. I agree, moving the profile view shouldn't have any effect at all.
    Lisa Pohlmeyer
    Nvidia Quadro 2000D
    Win 7-64
    Valued Contributor
    ccookusi
    10-18-2012 07:12 AM in reply to: JamaL9722060
    Don't do a move with a window or window crossing on objects.
    Move the "base" object by picking it, then everything attached to it will follow.
    Therfore, in your situation, move the "Profile" by moving the Profile View.
    Windows 7 Pro x64
    Civil 3D 2013 (SP1)
    Dell Precision T1650
    i7 3770
    NVIDIA Quadro 2000
    SSD Boot
    12 GB Ram
    10-18-2012 07:59 AM in reply to: JamaL9722060
    While I agree moving profile views with the grips instead of the move command is probably the better method should you need to adjust the profile view, have you regened after moving it? I have had this issue happen to me after moving a profile or section view. Some of the data appears to either get "lost in translation" or remains in the original location until I regen or regenall.
    Clayton Farrow
    Civil 3D 2012
    Windows 7 Professional
    Intel Xeon E31270 @ 3.4 GHz
    8 GB, 64-bit
    Valued Contributor
    ccookusi
    10-18-2012 08:01 AM in reply to: JamaL9722060
    Yes.
    You have to do a Regen
    Windows 7 Pro x64
    Civil 3D 2013 (SP1)
    i7 3770
    NVIDIA Quadro 2000
    SSD Boot
    12 GB Ram
    *Expert Elite*
    AllenJessup
    10-18-2012 08:06 AM in reply to: cfarrow
    That sound like it might be a video card or version issue. I don't see that in 2012. I move a profile view and everything shows in the new location immediately.
    Allen
    10-18-2012 08:16 AM in reply to: AllenJessup
    Allen
    Come to think of it, that hasn't happened since we switched over to 2012 a few months ago. It was more common when we were in 2011.
    Clayton
    Clayton Farrow
    Civil 3D 2012
    8 GB, 64-bit
